Question about Canon ZR65E Mini DV Digital Camcorder
Door opens "Slightly"
Please Help- We push the door button, it starts to open then it suddenly stops and will not finish or release tape, just opens slightly but seems stuck?
  • Anonymous Mar 17, 2014
    WE PUSH THE BUTTON ON THE DOOR TO REMOVE THE TAPE AND THE DOOR WILL NOT OPEN.
I had the same problem, and TomInMB
told me how to fix it:
What I did was to first remove the battery and AC power to "reset" the camera. I then put the battery back in place and WHILE HOLDING THE CAMERA IN THE UPRIGHT (AS IF USING THE CAMERA FOR VIDEO) POSITION, I pushed the "Open/Eject" latch. VOILA!
I haven't had the problem again. It may be that gravity helped to take the stress off the ejecting mechanism. Good luck!
Walt D in LV
http://www.thecinemaniacs.com/
Posted on Jun 12, 2008
When my garage door is in open position,it will go down about 2 ft. and return to open position with door connected to unit or not. It's a 3/4 hp Craftsman door Opener. Help please.
Try this...pull the door release cord. sb red, close the door manually all the way.
Push the door close button..when the unit stops re engage the emergency door release. open the door with the opener...close the door with the opener.
Hope this helps.
Dec 25, 2017 | Building Materials
My Essati electric garage roller door will not open further than 1/2 way following crashing into an object. It will close but does not know when to stop. How do I reset the door ?
Pull the red release handle to disengage the opener. Open the door with the remote. The door shouldn't move but the opener will operate. When it stops, physically open the garage door and push it all the way up. Now re-engage the release handle. GJiggle the door slightly to make sure the handle has engaged the opener. Now close the door. It should operate normally now.
Jul 25, 2016 | Building Materials
How to change the pin on Zebra Electric Push Code Safe from Justice.
1. Door has to be opened using previous code or the default "0000".
2. With door open hold the * button down. Both green and red lights will flash.
3. Within 15 seconds, enter your new 4 digit passcode while holding the * button. Press # when finished to store new code. Both lights will stop flashing.
4. Release the * button.
Jul 28, 2014 | Home Security
My Craftsman garage door will not close, only a few inches at a time
have a problem which returns every year when outdoor temperatures drop close to freezing. garage door will open only a few inches, then stops. I can close it and try opening it again... same result. After five or six such attempts it typically will open. Interestingly, when I push the switch button mounted on the interior wall of my garage and keep it pushed, the door will open, until I release the button at which point it stops opening.
Dec 19, 2013 | Building Materials
The door opens when i push to open but when i push to close it starts to close until i stop pushing the button. When i release the button the garage door opens back and clicks 10 times
Check the door sensors. They must be pointed at one another and the small light on each one must be lit and not flickering. Tweak them a bit. If you cannot get both lights to come on you have either a bad sensor or the wiring to them is shorted or broken.
May 11, 2010 | Sears Craftsman LiftMaster Chamberlain...
The door on my Smeg Allegra front-loader washing does not open
SOME MACHINES HAVE A DELAYED OPENING TIME SO THE DOOR DOSE NOT OPEN WHEN BUTTON PRESSED LOOK IN MANUNAL TO SEE IF THIS FEATURE IS ON MACHINE IF NOT PROBLEM THEN NEW DOOR LOCK WOULD BE IN ORDER
Dec 30, 2009 | Washing Machines
Push start button the dryer will tumble, but immediately stops
there is a relay that latches on when you push the start button .. that relay is released by the "door open" switch .. i would suspect that the "door open" switch is bad .. thats usually a button that is pushed in when the door is closed ..
Sep 19, 2009 | Kenmore Dryers
Accident turned on self clean with door open
I tried pushing in the light switch again, and i pushed it in until it stopped, evedently it is a 2 postion switch, when the door locks it pulls the door up tight, and the switch must sense this, so after I pushed the toggle in flush the lock finished locking and while I was still holding in the light switch I pushed the stop/cancle button and the lock opened up,and vola we could use the oven again, we had pizza.
Apr 11, 2009 | Kenmore Kitchen Ranges
Panasonic microwave door is stuck. The door is not opening
If you push in on the open door button and it just goes in and does not open the door, then the problem is that the plastic piece that actually opens the door has broken. You can verify this by removing the cover from the microwave and look inside. If you are handy just buy the part from the panasonic parts store in your city and replace it. If not take it in and they will replace it for you.
Good luck
Tom
Jun 12, 2008 | Panasonic Microwave Ovens
CT-W602R Dual Cassette Deck- door won't open
Dear etu7diante,
The another way to release the cassette from the deck is by moving the flywheel manualy after opening the cover of the system. The system should be disconnected from the power supply. If you are able to to do this please let me know .later I can guide you to do the job.
ramesh22
Jun 09, 2008 | Audio Players & Recorders
Canon ZR65E Mini DV Digital Camcorder Logo
307 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
