Try using engine oil.put oil in a little can oiler.oil the door hinges pins and bushings.if it still sqeek.door hinge need adjustment.or the door hinge pin and bushing need replacing.
Only three sources of squeak--the upper and lower hinges and the door position stop. You may need to use a stethoscope (mechanics) to pinpoint the source (sometimes, a screwdriver handle held to the ear and the shaft touching the offending part will suffice). If it appears to be a hinge, you can heat the part with a propane torch or hair dryer till it's hot to the touch and then apply oil which will be drawn-in to the hinge interior. Work the door back and forth to help the lubricant in. Oiling these parts on a regular basis stops this problem. Good luck!
