Question about Brother MFC 210C All-In-One InkJet Printer
Fax, phone line cable should be plug in "LINE"port or "EXT."
  • 62 Answers
The "LINE" port plugs into the wall socket.
The "EXT" port can have an analogue handset plugged into it.
Posted on Nov 17, 2009
Which port does the phone line plug in for fax capability
There are usually two telephone jacks on the rear - one is marked LINE and the other is PHONE or EXT. The phone line from the wall should go into the jack marked LINE. If you want to attach a handset as well, or pass-thru for regular calls, hook the phone to the PHONE or EXT jack.
Oct 03, 2015 | Canon Pixma Mx882 Mx 882 Photo All-in-one...
On the Fax part of the printer do I hook up a telephone line to line in port and Ext out phone port or just line in port to make the Fax work
You would connect the phone line to the LINE connection on the Printer/Fax.
The EXT OUT port would be where you would connect a telephone that uses the same line - for example on a desk nearby, etc.
Sep 16, 2011 | Computers & Internet
Using a toshiba e-studio 190f fax machine, i can not recieve a fax or send a fax. I call the line and it just rings, can youhelp
Make sure you have the phone line plugged in, also make sure it's plugged into the LINE port on the machine. (Ext. is for a extension, i.e. secondary phone for manual dialing)
Also check that the wall jack is functional too, easiest way to do this is hook up a regular phone to the jack and if you get a dial tone you know it's okay.
If the wall jack is getting a dial tone and the line is plugged into the LINE port you may have a bad phone cable, try a different one.
May 31, 2011 | Toshiba Office Equipment & Supplies
No dial tone on phone connected to ext port on epson dx9400f
Buy a double adapter so both cords go to the LINE port. Set your answering machine to 6 or 7 rings so the fax picks up first. Your fax machine will know the difference between voice and fax calls,
Jun 22, 2010 | Pitney Bowes 9920 Plain Paper Fax
No dial tone pressing hook, NG and Poor line condition transmission report on sending and receiving. Confirmed good dial tone on line in and on phone on ext. Copy, display, everything else fine. I hear...
Make sure that you have your telephone line from the wall jack plugged into the port on the fax that says "LINE" and that your telephone is plugged into EXT.
All your cables and jacks seem like they are working since your phone gets a dial tone, the onyl thing could be that the wires are mixed or the modem on the fax is broken.
Thanks,
Pat
Mar 27, 2010 | Brother Multi-Function Center MFC-240C...
Does not recognize phone connection --can not send fax or receive fax--no connection. phone line is direct--works good
Hi. Here are some things you need to check: 1. Check the physical connection. Make sure the phone cable you're using is still in good condition. No obvious defects. 2. There are two phone ports behind the printer- Ext and Line. The phone jack from the wall should be plugged in to the Line port of the printer and not in the Ext. port. 3. Make sure to enter your Fax name and the correct Fax number in the printer. These are the basics on how to setup the printer for faxing. Hope these helps.
Mar 21, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
On lexmark 7170 printer-when trying to fax-always get ''phone line error''-- connection is good from directline--phone works- Can't fax even without using pc I am using a Lexmark7170 printer with windows...
Hello. The "phone line error" usually comes up when the printer/fax is not connected properly to the fax line. Try to check behind the printer. There are two phone ports - Ext. and Line. The telephone cable should be plugged in to the Line port of the printer and the other end should go straight to the phone jack in the wall. If it is, try to use a different phone cable. Also, make sure that you assigned the correct fax number in your printer. Hope this helps.
Mar 20, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Cox comunications installed new modem and now the fax will not recieve or send
Make sure phone line is plugged into the right port. If you have two phone line ports on your fax machine, one is going to be labeled "line" and the other "ext" or "phone". You want the phone line connected to the line jack. This is assuming that you are not on Voice Over IP phone with the change from Cox. If you are, you may need to contact them to see how to connect your fax with your new configuration.
Aug 05, 2009 | Canon FAXPHONE L80 Laser
Can't get the fax to work. It WAS working before.....
follow this simple steps:
1 .Connect the phone cable that came with the printer to the back of your modem to the port that says tele 1.
2 . connect the other end of the phone cable to the port on the printer that says "1-line"
3. connect the phone cable or cord that came with your telephone line to the back of the printer port that says "2-EXT" and the other end to the back of your telephone ..
This should solve the problem..best of luck
Mar 26, 2009 | HP Officejet 7210 All-In-One InkJet...
Fax line setup
Plug the phone line cable into the line port and wait for an incoming call and don't answer the phone, the fax machine should do the rest. Let me know what happens.
Sep 06, 2007 | Office Equipment & Supplies
Brother MFC 210C All-In-One InkJet Printer Logo
117 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
