Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool dishwasher DUC600XTPQ acts like it is dead..nothing happens when I push the buttons, liek the power if off but I checked the breakers, now what? Help!
  • 90 Answers
Sounds like control is bad. cut the power, open door remove six screws at top of door the control panel will be loose. suport this remove black cover over control board by releaseing tabs shown by arrows. there is a fuse at lower right corner of board remove the two wires check coninuty if open replace it alongwith control board. hope this helps .haundi24
Posted on Nov 17, 2009
Testimonial: "Thank you so much! Sounds like something I could actually fix! Where do I buy the fuse to replace it?Is it like a car fuse? Thank you!!!"
Whirlpoool model du920pfgb3--touch pad is not responding and no lights or nothing are on??
Control panel. Try to push cancel button to see if it resets.if not google it and they will walk you through it.
Mar 28, 2013 | Whirlpool Gold 24 in. Built-In Dishwasher...
No lights on whirlpool quiet partner ii -- is it dead?
The main board sends power to the display lights. Check with a multimeter for voltage coming out of the main board to the display board. If no voltage the main board is bad or the fuse is bad.
Nov 25, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
The dishwasher won't start, its stuck, pots/pan button is blinking, & the timer has (2)_ _ bars blinking. I tried to reset/pushed the start/resume button nothing happened. I pushed the cancel/drain...
did you hold the start/resume button for at least 3 seconds if this works the dishwasher will start ok but if there is a fault it will fail again best you contact your nearest service agent good luck
Apr 07, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool DU1100XTPS 9 Dishwasher acts as if no power
Is your dishwasher have a power cord and plugged into a wall outlet under the sink if the answer is yes then maybe the GFI outlet has tripped and all you need to do is reset the button on the outlet
Sep 22, 2009 | Whirlpool 24 in. DU1100XTPS Built-in...
I have a Whirlpool Gold, had 4years,had to replace
Thermal fuse mounted to the control board see if you have power on each side of it checking from post to ground,if you got power going in but none going out it's blown,and has a more serious issue somewhere.
Aug 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Just won't work!!
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
I would also advise to check the door switch as well. make sure the wires are connected to the switch and it is working. replace if found to be faulty.
Check the control as well. if the control is malfunctioning as you stated, this will be the logical solution here. replace the control board.
May 29, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
No electricity
I would check to ensure you have power to the dishwasher and that the door is closing/secure properly.
(i.e, Plugged-in properly under sink/back or washer, check for tripped circuit-breaker, and door latch is grabbing properly)
Jan 27, 2009 | Maytag 24 in. MDB6100A Built-in Dishwasher
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked...
Hello mdonettaYou said,
Dryer shut off towels were not yet dry, turned dial to restart dryer acts as if it isn't getting power I closed door and pushed start button. Nothing! Checked breakers and power cord at outlet all checked okay. Any ideas.
yes, try unplugging the power cord or turning off the breaker for 5 minutes. Either will due. Some times the system needs to be reset!
If this does not work there are internal fuses that can be replaced!
Let me know how it goes!
Huuum
Sep 19, 2008 | Dryers
Normal Light Blinking - Dishwasher not working
I HAD THIS SAME PROBLEM. TRY PUSHING THIS SEQUENCE OF BUTTONS: HEATED DRY, NORMAL, HEATED DRY, NORMAL. THIS RESET MY PANEL AND IT IS WORKING NORMALLY NOW. I FOUND THIS SUGGESTION ON ANOTHER SITE.
Sep 14, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
233 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
