Question about White Sewing 2037 Mechanical Sewing Machine
What do I do with a ruller foot, #18 on page 6.
What do I do with a ruller foot, number 18 on page 6 of the manual? I'm looking for a foot that will help me make a very very small hem.
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Dec 21, 2016 | Sewing Machines
Have simple 3116. bought yesterday and today the foot fell off and i dont know how to put it back on!! help, please...
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example 3116 ) & click search
They usually have a free download
check page 16 to see if that's not the information you need
Aug 14, 2011 | Singer 3116 Simple
How do i put the all purpose foot back , mine fell off
Go to the home page
They have a free download
look on page 16 to see if that's the information you need
How does the all purpose foot go on, mine fell off
Go to the home page
check on page 16 about the foot
I took my pressure foot off while threading my machine and now I cannot get it back on. Have lost my instruction manual and don't know what to do. Please help
Go to the home page
In the box put the model number (example 1934D ) & click search
Aug 14, 2011 | White Sewing Superlock 1934D Mechanical...
How to fill a bobbin on singer sewing machine model 6268
Raise the presser foot and turn the hand wheel to put the needle at the highest position. Next open the slide plate by sliding it towards you. Make sure the bobbin is empty (remove any remaining thread or use a new bobbin). Slide the plate forward (partially closed) so that the arrow on the plate lines up with the arrow on the machine bed. Bring the thread from the needle under the presser foot and wind it around the presser foot screw (on the left of the assembly) once. Make sure that the thread is in the spring groove. Press the One-step Button hole A button (has a bobbin symbol by it). Then begin running the machine. Watch the winding process carefully and stop when you have enough thread on the bobbin. Do not let the thread continue to wind past the outermost line on the bobbin (black). Slide the plate fully closed and raise the needle. Pull the thread to the back of the machine to a length of 4" and cut the thread in the middle of the loop you just pulled through.
Now position your fabric under the presser foot, lower the presser foot and select your stitch. Begin sewing.
The manual is available for sale or download here: http://www.singerco.com/accessories/instruction-manuals/search . Just enter the model number. The direct link is: http://www.singerco.com/uploads/download/1272_6268-_-6268_6267-wholeas-of-6_23_05-special.pdf . Pictures for winding the bobbin are on page 16 (page 18 of the PDF).
I hope this helps.
(make sure that the machine is correctly threaded before starting to wind a bobbin)
May 25, 2011 | Singer Sewing Machines
Touch tronic 2010. machine continues to run with out the use of the foot control????
If you look at your manual, page 18 you are lucky enough to have one that doesn't need the foot control to sew. If, you do not have your manual handy, go to www.singerco.com and under customer support, download a free one.
Apr 15, 2011 | Sewing Machines
Have white sewing machine model 1866, it keeps binding up, the foot feed will not move like it should, is there an adjustment somewhere? is there an online manual somewhere?
On the singer website on the home page look for
Instruction manuals at the bottom of the page-click on it
Put in your model number w1866 & click search
Jan 18, 2011 | White Sewing 1866 Mechanical Sewing...
Want to sew light leather does it make a difference on what foot and needle I use. and I have lost the manual, where can I get another?
you have to use a needle for leather,, a walking foot or roller foot is better than a regular presser foot
brother.com has free operation manuals
on the home page go to the homesewing/embroidery on the left hand side of page
on the left side look for product manuals
on select product group select homesewing/embroidery & model number to download
Dec 13, 2010 | Brother LS-2125 Mechanical Sewing Machine
Every thing is missing
Go to www.managemyhome.com and you can download a free manual there. That will give you the directions to operate the machine as well as the Parts Numbers for any accessories you may want. I bought this same machine a few weeks ago. I have tested out almost every stitch on it, & almost the only 2 presser feet I have needed have been the Zigzag Foot (A) and the Satin Stitch Foot (F). Of course, if you want to do buttonholes or zippers, you will want hte Buttonhole Foot (R) and the Zipper Foot (E). Parts Numbers for ordering are listed for every part on page 6 of the manual. Good luck!
Jan 29, 2009 | Kenmore 19606 Computerized Sewing Machine
White Sewing 2037 Mechanical Sewing Machine Logo
56 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
