Question about Casio FX-115W Plus Calculator
What does the xbar look like on the calculator
  • Casio Master
  • 7,993 Answers
Usually it is represented by a small letter x with a short straight bar on top of it. Sometimes it is an x with a small caret (hat, accent circonflexe) on top of it. I do not have the layout of your calculator, but if you see on the body of the calculator a small n (the number of entries), a greek capital sigma σ or a small sigma σ with x (xσn or xσn-1) standard deviations, the xbar is not far away.
Hope it helps.
Posted on Nov 17, 2009
Find mean ti30xa
Clear the statistics registers with 2nd [CSR]. Add the data points with Sigma+. Errors can be corrected with 2nd [Sigma-]. Calculate the mean with 2nd [xbar].
See the example on page 11 of this guidebook.
Feb 24, 2013 | Texas Instruments TI-30XA Calculator
I have 50 data points for which i need to find standard deviation on a classpad 330 , is there any quicker way to calculate than minusing the mean from every data point?
Here is one technique I used on the TI84Plus.
Create two lists list1(50) and list2(50) of equal dimension (same length)
You will have to find how to do it on ClassPad.
Fill list2 with zeros
Fill list1 with your data.
Sort the list in ascending order (if it is not sorted)
Do standard deviation calculation on list1 (or calculate the average)
The mean of the data is in a special variable (xbar)
From the command line using the list syntax calculate abs(list1-xbar) and store results in list2, overwiting the zeros.
Perform standard deviation on the new list2. You will get the mean deviation from the mean in the variable xbar.
A simple request from you. Can you please not use MINUS as a verb? By doing so you are propagating incorrect usage. There is a short and correct way to express the operation: to add.
May 05, 2012 | Casio ClassPad 300 Calculator
When I type in stat, then edit, t fnd the mean and the median, which is which? Because there are about 9 different answers???
The mean of a distribution is represented as an x with a bar above it. (xbar). When you scroll along the statistics you will see the Median, Xmax, Xmin, Q1, Q3, n. All clearly identified. Maybe you should learn mor about the theory.
Nov 09, 2011 | Texas Instruments TI-84 Plus Calculator
How do I use the standard deviation function?
  1. Calculator must be in SD mode (standard deviation mode) :Press [MODE] [.]
  2. However, if [FIX] or [SCI] appears on display you must press [MODE][9] first.
  3. Data input always starts with [SHIFT][SAC], to clear the registers of old data.
  4. Type a number and press the [DATA] key, it is the [M+] key at the bottom right of keypad.
After you finish entering the data
Press [SHIFT] [9] (sigma n-1) to get sample standard deviation
Press [SHIFT][8] (sigma n] for the population standard deviation
Press [SHIFT] [7] (xbar) for the mean
Press [SHIFT] [6] (n) for the number of data entries
Press [SHIFT] [5] (capital sigma x) for the sum of values
Press [SHIFT] [4] (capital sigma x to y) for the sum of squares of the values
For additional information you might consider taking a look at the calculator manual.
Apr 30, 2010 | Casio FX-260 Calculator
How to use that standard deviation on the Casio fx-260solar calculator
Apr 27, 2010 | Casio FX-260 Calculator
How do you use the statistics function to find out the mean?
Press [2ndF][MODE][1] to select single variable statistics.
  1. Enter a value and press [DATA]
  2. or enter value, press [X,Y]key, enter the frequency then press [DATA
When finished you can access the mean (xbar an X with a small horizontal bar like a minus sign on top of it.)
The xbar may be a key accessed directly if xbar symbol is on top of the key, or a [2ndF] key if xbar is written on the body of the calculator.
Feb 03, 2010 | Sharp EL-531VB Calculator
How do you calculate standard deviation?
Jan 26, 2010 | Casio FX-260 Calculator
How to find standard deveation
Dec 15, 2009 | Casio FX-260 Calculator
Having trouble with standard deviaation and X bar using Casio
Here is an example from the manual.
Hope it helps.
Feb 26, 2009 | Casio FX-115W Plus Calculator
How to compute standard deviation given a set of numbers?
Jan 15, 2009 | Casio FX-260 Calculator
Casio FX-115W Plus Calculator Logo
85 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
