Question about HP Photosmart C4150 All-In-One InkJet Printer
Just replaced the glass on an HP C4150. When I use the copy feature all it prints is verticle black lines. Must be somethihng with the scan head as otherwise the printer prints okay.
    Brigadier General:
  • 4,088 Answers
Look for debris on the scan head face--all it takes is one tiny speck to create one line down the paper. Make sure the connector for the head is plugged in securely on both ends.
Posted on Nov 17, 2009
I have a hp officejet pro 8500a and it has started leaving a black line on all copies when the original is fed thru the ADF. What is causing this??
Hi, Change first black color print head cartridge just open cover then replace black print head cartridge.close cover wait for ink cartridge reinitialize if ready print test again.if same print having black line all copy needs to replace also black ink cartridge.
Jun 30, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
The copier feature of my new HP all-in-one Officejet Pro 8500A Premium is printing with vertical black line just right of center, whether black or color copy is selected. I have dusted, air compressed and...
lift up the feeder on top of machine where your big piece of glass is. to the side of that big glass is a small glass about an inch wide. most likely there is something on it. clean and you should be good to go.
razors
Jun 01, 2011 | HP Office Equipment & Supplies
Hp laserjet 2010 prints black line down side when printing scans from paperport 11
I have no idea what "paperport 11" is.
That being said, normally a line down the page when copying or scanning is caused by dirt on the Automatic Document Feeder glass, Not the flatbed glass. It is a thin strip of glass to the left of the flatbed scanner glass. Clean it.
Jan 11, 2011 | HP Office Equipment & Supplies
Black vertical lines on copies and scans from auto
This means the read area is dirty. Clean the glass with glass or lens cleaner at the area where you place the head of the paper if you wanted to lift the cover and scan a page without the autofeeder. There may be white out or toner stuck to the glass. This can be removed with a glass blade.
This answer assumes that prints from the computer are fine...
Apr 03, 2010 | HP Officejet 6500 Wireless All-in-One...
HP OfficeJet J5780 Vertical Black Line Prints when copying or scaning only. Cleaned rollers and changed black ink cartrigde. Still problem.
Have you tried cleaning the document feeders Scan Glass? (small glass under doc feeder ~ 1" by 9") Most times there is dirt spot on this glass, causing a shadow on scans and copies.
Try copying from the large glass by lifting doc feeder / platen cover and manually placing original. If no line copying or scanning manually from large glass, then small scan glass is deffenitely the culprit. Hope this helps.
Sep 07, 2009 | HP Officejet 5780 Printer
HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Jan 28, 2009 | HP LaserJet 3055 All-In-One Printer
HP 3050 Black Line
I was getting a verticle black line and I had to clean the glass, the long white bar above the glass, and the white and black rollers before my problem was solved.
Mar 12, 2008 | HP LaserJet 3050 All-In-One Printer
DELL 1600N
If it makes verticle lines only when using the document feeder it is most likely a dirty glass strip over the scanner light bar. If it makes verticle lines in all modes (printing, flat bed scanning/copying, receiving faxes) it could be the fuser or a dirty glass over the laser where ever the laser images to a drum roller (usually a larger green roller). It is possible that this green drum roller is inside the toner - if so - replacing the toner cartridge could fix it. Maybe you could try an old used toner to see of the problem changes - if so - it is very likely that a new toner would fix your print quality issue.
Jan 09, 2008 | Dell 1600n All-In-One Laser Printer
Scanning document leaves streak down right hand side
hmm this has happened before
make sure it is sitting straight and cleaning it might help
Jan 07, 2008 | HP PSC 1315xi All-in-One Printer
HP Photosmart C4150 All-In-One InkJet Printer Logo
88 people viewed this question
Seeker5211
Seeker5211
