Question about RCA DIRECTV Satellite Remote Control
I have a direct tv remote. the green light at the top is continuously blinking. I can remove the batteries and replace them and it still blinks. the remote i have is white and about 2 inches wide. I forgot the model #.
3 Suggested Answers
SOURCE: volume not responding on Direct TV remote
http://www.directv.com/learn/pdf/System_Manuals/RCA/RCA_DRD221RD.pdf
See Page 15.
Worked like a charm! Good luck!
Posted on Nov 28, 2008
  • 814 Answers
SOURCE: RCA direct TV remote
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1] Please copy this web page link and paste it into the address bar of your web browser. This web link will take you to the RCA customersupport web page for programming universal remote controls and listscodes under system components. The television codes for the universalremote are listed under TV. This web page should be able to help yousolve your problems with the programming of the universal remotecontrol and give you the codes needed to use it with the components inyour system. Thank you for using Fix Ya and have a nice day.
Posted on Jun 19, 2009
Direct tv cannot find a code to program direct TV remote
Hi
The following codes should work with your model
12293,13382 ,10178 ,10000 ,11034
Setup Instructions
  1. Turn on the TV manually or using the original TV remote.
  2. Press and hold the "Mute" button and the "Select" button on the direct tv remote at the same time until the green light on the top of the remote blinks twice.
  3. Using the number key, enter the first digit of the code above. Wait for the green light on top of the remote to flash twice
  4. Enter the remaining 4 digits of the code as above.
  5. Aim the remote at your TV and press the "OFF" key once. Your TV should turn off. If it does not turn off, repeat the steps above, trying each code until you find the correct code.
    www.electro-medical.blogspot.com
Sep 07, 2015 | Haier HL32R 32 in. LCD TV
Green light continues to blink
These blinks are fault indications, called blinking codes. To count the blinking codes to Philips brand Televisions are some what different. It cannot be counted directly. If you wish to get more details about how to count the blinking codes, and convert it into fault codes, check the site linked here. It is very difficult to type in all here by this window. http://electronicshelponline.blogspot.com/ Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jul 09, 2013 | Philips 32PT6441/37 32" TV
TV is slow to start up. Green light blinks for a long time.
take it to mechanic,because it not repair by a common man at home..
Jan 04, 2018 | Toymax Magnavox 37MF231D 37 in. LCD TV
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
The tv's green "on" light continues to blink on and off. when we turn it on at the remote or at the on/off switch on the side, it won't turn on. we have unplugged it and the light continues to blink. We...
Try pressing and holding the remotes "Power on" switch as it may be a child lock that is activated. Otherwise try holding the tv "Power on" switch. Hope this helps.
Jun 19, 2010 | LG 42LC2D 42 in. LCD HDTV
Kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Jan 22, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
Ws 55513
The constant blinking green light means that the TV is not booting up. This is a common problem on this set.You need to remove the shield from the DM board (standing upright on the left where the DTV RF connector is)and inside you will see the four leaky capacitors (1000 MFD 16 VOLT)replace them,plug the TV in and wait 70 seconds for the blinking light to stop,then turn on the TV.The hard part will be removing the board from the TV(lots of screws and connectors,takes time)
Sep 22, 2007 | Mitsubishi WS-65613 65" Rear Projection...
RCA DIRECTV Satellite Remote Control Logo
1,355 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
