Question about Pioneer DVR-640H DVD Recorder/HDD Recorder
Hard drive shows full even after erasing 120 hours.
My dvr-640 h worked good for 14 months. when the hard drive became full, I erased a couple hours of recordings only to see it still read full. I tried to optimize it but it keeps saying "optimizing not complete. please optimize again. I did. Still won't optimize. Also, I deleted another 120 hours off the drive but still reads full. I did the factory reset as well as unpluging for days at a time. Nothing works. According to the manual, If the hard drive freezes, the "hard drive initialize" option appears under disk set-up. It Doesn't. I called pioneer to see if they could send a bootable disk to initialize the hard drive. They won't! I guess I could remove the hard drive and put it into a desktop to anylize it but I don't have that comp with me here, only my laptop. Anyone know of this happening to anyone else? Please advise.
  • darrinlh Apr 07, 2009
    Same problem -- the hard drive remains full even after deleting programs and I'm unable to optimize the HD. It will sometimes start and run for a minute, then quit, but usually just quits right away. Also, I can edit programs by deleting content only at the beginning or end, not in the middle.
Melnavz does not what he is talking about, and he give a extreme bad adviced. If you carelessly remove the hard drive it will bricked your dvr. Before you mucked around with the hard drive, make sure that you have the Pioneer Data Service Disk GGV1273 type 2 DVD and Pioneer service Remote control. For more infos follow the link below:
http://www.pioneerfaq.info/english/replace_HD.php
Good Luck!
Posted on Aug 25, 2009
    Genius:
  • 1,226 Answers
You should empty the recycled bin in the system and delete all temporary files on it.
Posted on Jan 10, 2008
  • Emelio Navaja
    Emelio Navaja Jan 10, 2008
    If your planning to connect to the laptop , you should provide HDD enclosure so that you can connect via USB port and you can clean out all not necessary files.
Keep getting error message when I try to back up
Hi Steffani
Thats not much Info to go on.....?
Are you using TimeMachine or perhaps Carbon Copy Cloner to "BackUp"?
Is the drive full? Click on drive icon then Cmd I for Info.
Use the Drive Utility in your Applications / Utilities folder to wipe and erase & reformat your hard drive.
The best way to Test your drive is to Run the Drive Utility once a year, If security Option is selected it will test the whole surface for faults. But it takes 2-3 hours (good for overnight test)
Make sure you copy any needed files first.
My rule of thumb is
If your in an Office environment working on the computer all day then use TimeMachine
Otherwise use CCC as TimeMachine hourly backups are a waste of time for the average home user. And harder to recover data.
One CC Clone made every couple of months is adequate and if you need a little more then drag the USER folder over to the external HD each week. The rest should be in your clone, Which.... By-The-Way is Bootable in an emergency,
Thats why we call it a Clone.
Just hold the option key down directly after Power On.
The choice of boot drive will show up on Screen.
Cheers
Was this helpful.... then how about a simple Tick of Approval?
Mac Backup Software
Sep 14, 2015 | Maxtor OneTouch III Mini Edition 120GB...
Erasing a maxtor III mini 80d drive
Plug it in
then right click on my computer
select manage
on the left side select disk management
locate your usb drive and the partitions on it
right click on them and select delete.
May 31, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Dvr will not record. i get the message, " hard drive full" is there a way to erase what is on the hard drive?
You can erase the contents of the drive or set the drive to overwrite when full. Erasing the drive is the equivalent of reformatting (you will not be able to recover the images easily).
To Erase/Format, enter the Menu system and select Hard Drive Setup (seventh line in the list). Press Enter, then go to HDD Format (fourth item in the list) and press Enter. Then enter your password (set up under System Setup) but the default password is 111111, if it is on. If you entered the correct password, the screen will flash HDD Formatted 3 times. Press Menu to exit the menu. (If the incorrect password was put in, Incorrect Password will flash.)
To overwrite, again go to Hard Drive Setup then select the first item, Drive Full. Press Enter to toggle Overwrite On or Off. You will be able to recover the images until they are overwritten.
I hope this helps.
Oct 13, 2010 | CSi Speco Speco Technologies DVR-4CF...
I can not put a desired event on recording thru"create timer"scre
aparfenov
The receiver hard drive is comparable to a computer hard drive. When a problem is detected with the hard drive, the receiver will give an error message stating a problem has been detected. Depending on the severity of the problem, sometimes it will show that unplugging the receiver for 1 minute will resolve the issue. Other times, a message will state that the hard drives needs to be reformatted, which will erase all content on the hard drive. It sounds like this is what happened to your recordings. If unplugging the receiver did not resolve the issue, we may need to replace the receiver. Please call 1-800-333-3474 and speak to a Technical Support agent.
Ray Calo
DISH Network
Apr 25, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Recording
I have the same problem. I believe this unit is a lemon by Samsung. I was so exhausted I went to Hard drive erase. After I erased the HD, now it will not record or go into recode mode. I think all it good for now is just to view the monitor. When I call Samsung they dont have a clue what a DVR is. I never seen a company so illerate. They cant even tell me where I can send it for repair.
Feb 12, 2008 | Samsung 4 Channel Dvr
DirectTV Dvr Playback of Recording skipping and locking up reciever forcing Resetof reciever.
Have either of your tried unhooking the HDMI connector if you are using it and try component?
What software are you running on the unit. The HR20-700 and HR20-100 just got a software update that was going to fix this problem w/ the unplayable recordings.
stephnt:
If it is erasing your content that is a good sign of a defective hard drive. These units when they boot up (after a software update) check the hard drive. If they run into a problem (bad sector) they will foolishly erase the hard drive, thus erasing everything you have recorded. If this is your 4th unit, you may want to look at your environment as well (well ventilated, good connections, etc) I'm not saying it couldn't be the unit. It took directv 14 units to get 3 working, and since I've had 2 HR20-700 refurbs that were unstable and were quickly replaced.
It might be in your best interest to invest in an external drive solution for the HR20. I, however, would be calling customer retention and having a calm, but stern chat with them about this.
Nov 16, 2007 | Directv Plus DVR DTV Receiver / 100-Hours...
Faulty hard drive
Your hard drive needs to be replaced. They don't tell you in the operators manual, but these drives are extremely vulnerable to shock (even a 1/4" drop can kill them) and temperature change.
These machines are not sophisticated enough to mark bad sectors and work around them. Without a new hard rive, your machine will not work.
It is very unlikely, but there is a tiny chance you could reset the hard drive with a service remote. But considering how expensive and difficult it is to get a service remote, it is not worth the effort. You would also need a service manual, whic BTW is not particularly good, so you would need a lot of time and the chances of success are very small.
Considering repair costs, you may be better off financially to get a new DVR.
Oct 01, 2007 | Pioneer DVR-520H DVD Recorder
Set has intermittent short freezes
It is possible for the hard drive to fragment and in that case doing an entire hard drive erase and format should clear up that issue, but if it does not try looking at a possible buffer issue and the need for a software upgrade, I have seen this happen in some cases. DVR should go through an erase and reformat at least once every two months since you really should be storing your movies on a separate hard drive and using the internal hard drive for just temporary storage for viewing.
Sep 07, 2007 | Philips DSR708R DirecTV / TiVo DTV...
Pioneer DVR-640H DVD Recorder/HDD Recorder Logo
598 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
