Question about RCA Scenium HDLP61W151 61 in. HD-Ready Television
My HD44PLW165YX1 Tv will not come on. none of the light in frount work there is no sound nor picture.
  • 460 Answers
Usually the scenium tvs that rca produced had coolant leakage and small signal board issues.. call a tv service shop and have it looked at..
Posted on Nov 17, 2009
I have a sharp lc46d43u the power light is green, have sound but no picture and none of the buttons work except the power button
Have you had a power bump or spike just prior to your problem. If so I would call the support for that TV and ask what the reset pattern is for the set. It can very from manufacturer to manufacturer.
Sep 22, 2014 | Sharp Aquos Televison & Video
73 mitsubishi dlp tv 73737 has sound but no picture with red light in frount
You need a new lamp. The red light means the lamp failed to turn on.
You can find cheap ones on ebay for about $40. If you go to best buy they will charge an arm and a leg. You can change the lamp yourself and it will take less than 15 mins to do. The only tools youll need are a phillips screw driver and maybe a flat head.
Jan 26, 2014 | Mitsubishi WD-73827 73" HDTV DLP TV
No picture or sound
how about a light indicator, is there a light at the front panel of the tv?. if none check the power supply first, which may have blown fuse at the primary of the power supply.
Jul 18, 2012 | Sanyo PLV-55WM1 55" HDTV-Ready LCD TV
No picture on TV
is your tape stuck in the unit ?
Jan 27, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Xbox 360 has sound but no picture
1. Check cable
2. check cable connections to the back or frount of the TV
3. make sure the YELLOW plug is in the CORRECT yellow port 9 times out of ten this is your issue.
Otherwise if these are not the case try the unit on another TV, If that does not work you might have a bad video card insde and thus causing a warranty repair witch if its out of warranty this would run !50 upwards to fix , thanks
Oct 06, 2009 | Microsoft Xbox 360 Console
Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
Oct 02, 2009 | Toshiba 42HP66 42 in. LCD Television
Vw37l no sound no picture
yes that is what you need main board.i have
47 inch with same problem and I put the main board and now is working
Aug 18, 2009 | NEC PX-42VM3A 42 in. EDTV-Ready Plasma...
Sound but no pic
You need to take this television in for service for component failure. You can contact PROSCAN customer support at this website. www.oncorpus.com. Go to the customer support section and ask them where you can take you television for service. You can also call the customer support at this telephone number. 1-888-977-6722. I hope this information helps with your problems.
Mar 31, 2009 | Proscan 32LA30Q Television
Light always seems too low
keeppressing fn button than frount & back button press
frount button for the increase light
back button is for decrease the light
Jan 03, 2009 | Computers & Internet
RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
129 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
