Question about Jenn-Air JEC0530ADSCooktop
Jenn Air JEC 0530 Cooktop shutting off
Our Jenn Air JEC0530 was working well until we used it on Thanksgiving and had all the elements going. It cut out and seemed to have overheated. Once it cooled down we were able to get it to turn back on. However, now the fan is noisier and it shuts off if only two burners are on. Very frustrating, and we've had it just over a year.
fridgetech
  • 473 Answers
SOURCE: knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Posted on Oct 19, 2007
  • 1314 Answers
SOURCE: jenn-air downdraft fan not working
there are 4 wires for that red white black and green sure you didnt miss a wire
Posted on Dec 30, 2007
SOURCE: Jenn-Air Gas Cooktop Model CVGX2423
Just had this problem today on our seven or eight year old Jenn-Air cooktop. When using the front right burner all ignitors would continue to fire until I turned off the burner. The three other burners worked correctly. After trying all the obvious soulutions w/o success I pulled off that burners control knob and the rubber seal which exposed the valve. Their was a bunch of crud in there. I put a small (one inch) paint brush in there and vigorusly loosened all the crud. I then inserted the nozzle of our central vac - which just happened to fit perfectly - and sucked all the stuff out. I repeated the proceedure a couple more times, reassembled the knob and started the burner. Worked just perfectly!!! YMMV. Good luck.
Posted on Feb 08, 2008
  • 905 Answers
SOURCE: Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
when you turn the dial a switch is engaged to start the ignitor , or if there is a sensor(one for the two bottom , one for the two top , it may not be reconizing that they are lit ,or the problem is sticky switch in the the dials, but I believe its a sensor that detects both of those burners that stops the spark
Posted on Oct 20, 2008
SOURCE: downdraft vent on jenn air cooktop
How do you get the inside area of the vent clean from the grease and oils where the filter is?? I have a rectangular box style downdraft that the vent goes into the floor, I pulled the filter, but the box is to slender to get an arm into to scrub the grease....... does the bottom come off, or is it a sealed unit? How do you get all the brease from the bottom if you cannot reach it?
Posted on Nov 30, 2008
I have obtained a replacement element Whirlpool AP5653770 for my Jenn-Air JEC8430ADS cooktop. I have lost the secmatic I made showing the colopr of wires going to each position on the element. I have a...
This is the correct way to wire the right front burner on Jenn-Air JEC8430ADS cooktop. Let's do the red wires first. The red wire that comes from #2 on the switch goes to the common connection for the element that should be labeled 2a. The other red wire goes to either of the "b", hot surface indicator switch contacts and the black to the other. Use 1b or 2b for these connections whichever reaches easiest. The yellow wire goes to the inside loop of the burner and the tan to the outside element.
Dec 04, 2013 | Jenn-Air JED8430 Electric Cooktop
I have a Jenn Air JED 8230 cooktop with a bad heating element
They are not that hard to replace and you can easily buy the part online...
Here is a tip about how to buy appliance parts online.
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
heatman101
Jun 28, 2010 | Jenn-Air JED8230 Electric Cooktop
I'M LOOKING AT A USED COOKTOP BY JENNAIRE MODEL #JEC 8536ADW SERIAL #10672300CC. HOW CAN I FIND OUT HOW OLD IT IS. IT LOOKS ALMOST NEW
How old is my appliance?
Brand: Jenn Air
Type:
Country: USA
Model: JEC8536ADW
Serial: 10672300CC This product appears to have been manufactured February of 2003. (MAYTAG-10)
Sep 29, 2009 | Jenn-Air 35 in. JEC8536A Electric Cooktop
What is the cabinet cut out for a Jenn-air 30" prostyle cooktop model# jcp430adp. The manufacturers specs are not specific
The pictures that are posted on the Jenn Air site are confusing. I waited until I received the unit to make the cuts. I am glad that I did.
Jul 18, 2009 | Jenn-Air 30 in. Pro-Style CCGP2420P Gas...
Spot on Jenn Air smooth cook top stove with down draft.
Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
My jenn air cooktop only gets warm and only has 110 volts?
how old is the cooktop? may have a broken or disconnected wire in it.
Oct 26, 2008 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
Knob not working and some burners not heating
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Jenn-Air JEC0530ADSCooktop Logo
76 people viewed this question
Top Jenn-Air Cooktops Experts
Dan Webster
Dan Webster
jason
Are you a Jenn-Air Cooktop Expert? Answer questions, earn points and help others
