Question about Linksys Wireless-G WRT54G Router
Wireless I just set up my wireless modem and when i get on my laptop the name of my airport shows up but when i put in my password it continually says that it is not correct. why is that? i even printed the information off the the linksys setup and my password is correct that i am typing in
  • 61 Answers
If you are sure that you are typing the password in correctly chances are that your particular Router / Computer combination can not support the type of security that you used. You will currently be using either "WPA" or "WEP" I recommend trying the OPPOSITE setting out.
This is the most common cause of your problem.
Let me know if that works!
Posted on Jan 10, 2008
I am trying to connect a mac to the router - need some help
. you will need the "airport " networking gear
2. If you have a base station you need to connect this to your router or modem with an Ethernet cord ( RJ45)
3. Connect the base to the MAC pc Ethernet port.
4.connect the base station power and look for the power light to go on.
5.Open MAC applications folder then the "utilities " sub folder.
6. Double click the "airport utility icon"
7. Base station on the left of the screen ( click) then choose "continue".
8. if not on the left of the screen then select "setup a new station" then click "continue .
9. enter password for the base station ( write it down) keep it . click "continue".
10. next select create and new wireless network
11. create a name for the connection
12. then select "WPA" for the security then type in a password
13Next .make a selection for either a router or modem the click "continue.
14. next select DHCP the click continue
15.Verified then click "continue" then wait for the restart of the base station.
16. You should see "congratulations" then click "quit"
Aug 13, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I'm trying to get a dynex DX-E402 to join my airport express
1.Log into router
2. Verify wireless router name( on the computer) >>> ( on/off)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
Jul 01, 2010 | Dynex DX-E402 Router
How to use apple time capsule and apple base station together?
Basically Time capsule is same as Airport extreme base station added with a hard drive to take wireless backup.Put same Network Name and password in both Time capsule and airport base station.Suppose your are making TC as a primary base station and Airport extreme as a secondary base station. Select WDS in both the base stations .In "Wireless Mode" select"Participate in WDS network" in both the base stations.Dont change rest of the options.Put TC Mac id to Extreme base station and extreme Mac ID to TC.now open the airport option in your laptop and check.you can see a single network name.Its DONE.Njoy using wireless
Mar 31, 2010 | Apple MacBook Pro Laptop Computer with...
Macbook and wireless n setup how do you set it up????!!!!!
Can you clarify the problem for me:
1. Mac Type = Macbook
2. Operating System = Mac OS ?
3. What are you trying to connect to?
For example are you trying to set up a Wireless Home network, meaning that iPhones, iPods or other macs can share the one Internet Connection. This is called a Computer-to-Computer Network.
OR are you trying to configure a Wireless Modem to work with your MacBook?
Setting up a Computer-to-Computer Network is done by:
1. Select System Preferences from the Apple Menu.
2. Select Network from the Internet & Wireless section.
3. Select Airport from the list of devices.
4. Click the Turn Airport On button, located next to Status. NOTE: If it is already turned on then this button will read Turn Airport Off.
5. Select Create Network from the drop down menu adjacent Network Name.
6. Type in the preferred name that you wish to call your network in the Name field. (ie., MacBookHomeNetwork or something)
7. Select the Channel (Channel 11) is an OK one to select.
8. Choose whether you want the user to type in a password to gain access to your network. (This is recommended.) If you do, then click the check box beside Require Password.
8.1 Type in the Password into the Password field.
8.2 Type the Password again into the Verify field.
8.3 Select the type of encryption you want to use, 40bit or 128bit.
9. Click the Show Airport status in Menu Bar check box.
NOTE: If you require advanced settings, then click the Advanced ... button.
10. Apply and then go back to the System Preferences window (using the Left Arrow located top/left of window). If you get stuck, get back using Instruction No.1 above.)
11. Click the Sharing Icon in the Internet & Wireless section.
12. Select from the list each item you wish to share (i.e, File, Printer, Bluetooth, Internet, DVD or CD etc...).
NOW : From your other device, you need to locate the new Wireless Network Connection.
If it is an iPhone or iPod then go to the Settings menu and select Wi-Fi from the list. The new network should be picked up automatically. Log in to it (if you set up passwords).
I hope this helps. Regards,
Feb 05, 2010 | Computers & Internet
I would like to set up a password but dont know how to go about it
Connectcable modem to PC / laptop start web browser and enter IP address (like 192.168.1.1.) ofmodem, log in with admin / admin now you are in menu of modem securityand go to fill in what you want as password
save it and if you want make connection to the net you have to fill in the paswoord you put in
on the back or botem are a small hole this wil reset the modem and login paswoord
Nov 01, 2009 | D-Link AirPlus DI-524 Wireless Router
Need apple router expert. I have an imac g5 with airport wireless card. I have created network on the mac. I just bought a toshiba satellite laptop (windows vista). Cannot connect wirelessly.
Hi! if ur other mac computer can connect wirelessly except for the sat laptop-vista. i dont see any problem to the router, bcoz my i have a client who is using a mac with airport wireless, she can connect to the internet using a linksys wireless router.. if u are able to view the wireless name of ur router from ur sat laptop and u are able to connect and it shows on ur computer that ur connect after selecting the ssid of ur wireless network either u enter a password or not.. try to set ur internet browser security settings to medium, how to: pull up the browser and select on tools and internet option then internet properties will show, select on security, set to medium and uncheck the enable protect mode..then apply the settings, rmove also the cookies at the general tab. i hope this will help, pls free to get in touch if u have any question..
Aug 13, 2009 | Computers & Internet
I can't connect apple airport expresses with a siemens 587 route
Login to your airport express using Apple's airport utilities (either in it's current configuration or after resetting it).
Using the airport utility do not choose manual setup, just select continue.
Adjust (as required) the airport express station name and password and select continue.
Select "I have a wireless network and I want to add AirPort Express or replace an existing device on my network and select continue.
Select I want Airport Express to wireless join my current network and select continue.
Choose if you want to extent the rance of your network or just join the network and select continue.
Choose the network you wish to join... etc etc etc....
You should be fine.
Jan 31, 2009 | Apple AirPort Extreme Base Station
Zyxel wireless router password
hi . do you guys cant access to your wireless router ? if yes than try this
reset your modem by pressing reset button on your modem for more than 5 seconds so all the information entered will be gone including your password
than insert your modem CD and connect to your modem
set up your internet again
put your password and user name that your ISP gave you
set : get IP from ISP
get DNS from ISP
APPLY
than go to wireless setting
use wpa- personal
and set up a new password eg. (usa2008)
than it will say your computers and network setting doesnt match
go to connect find your modem
right click on it
click on properties
than go security
choose WPA- personal
TKIP
and your password (usa2008) you set to your modem
connect to your internet
im not sure if this is what you mean / thats how i anderstood your problem
NOTE : RESET YOUR MODEM IF YOU HAVE ALL YOUR INTERNET SERVICE INFORMATION
BECAUSE IT WILL DELETE ALL INFORMATION IN YOUR MODEM including user name / password / IP / DNS / and your modems password
Aug 17, 2008 | Zyxel Prestige 660HW Wireless Router...
Wireless Modem don"t connect
well imac G4's don't  have built in airport (wireless internet) included as usual with apple its another item you must buy an airport extreme card  then hook it up to an airport base station another item to buy via wireless internet then hook you airport extreme base station up to your modem via ethernet. whew ok now sync the airport base station to your imac using airport set up application then select your network and type your WEP password and viol internet in about 1 hour if your lucky hope this helped my fingers hurt now LOL.
Apr 07, 2008 | Apple iMac G4 Desktop
Wireless not working
Check for the wireless security settings in your modem.. and check if your airport is connected properly, if it is connected properly, then you would get a valid ipaddress, try resetting the modem and reconfigure your wired and wireless settings, if possible , try to upgrade the latest firmware for your modem and then reconfig it..
Jan 21, 2008 | 2wire (1000-000057-000) Modem
Linksys Wireless-G WRT54G Router Logo
15 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
