Question about Lexmark X1290 All-In-One InkJet Printer
Lexmark x1290 all in one. how do i clean the pritner jets ?
I have a lexmark x1290 all in one. the problem is the ink printer jets are clogged. how do i clean these so the printer actually works? thanks for your time!
    President:
  • 2,351 Answers
There are a few things you can try. First run the printers cleaning software that was installed.
In a windows XP operating system, Click the start button, than slide to and click on Printers and Faxes. Your default printer will have a check mark to the right of the printer icon. Right click on that icon. A pop-up window will open, slide down and left click on "Properties". Than click on "Printing Preferences". Next, Click on the "Services Tab". Than, click "Service this device". You should be able to run the, "Clean the Print Cartridges". After the printer finishes cleaning, print a test page. If this helped but not enough than manually clean the ink cartridge' (s). Remove one ink cartridge and lay it onto a few paper towels. Take a clean lint free cloth and dampen it with some water. With the print heads facing down slide it across the dampen cloth a couple of times. Now clean out the ink carriage. Dampen some cotton swabs and clean the inside of the carriage. Use dry cotton swabs to dry the carriage. When you look into the carriage you'll find a copper plate with dimples. Use a drop or two of house hold alcohol and wipe the surface of the copper. Re-insert your ink cartridge. Repeat for the other cartridge and carriage.
Water breaks down any dried ink. The alcohol removes oils. Below is a link to Lexmark;
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x1290&productCode=LEXMARK_X1290&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X1290&searchid=1258425000955#1
Alway keep your printer openings covered.
Mike
Posted on Nov 17, 2009
What ink do i use ? lexmark x1290.
Here is the list of ink cartridges that you should use with your Lexmark x1290
Go to this link:
http://www.lexmark.com/uncomplicate/product/home/242/0,7044,577054412_599489036_932120818_en_0_7,00.html
Keep me posted.
Jas
Feb 18, 2011 | Lexmark Office Equipment & Supplies
Some of the ink-jets that shoot the ink onto the paper are clogged. Use the Lexmark software for the printer to run a few "print-head-cleaning" cycles, to try to unclog it. How do I find...
You can try to clean the head manually with a cloth damoened with warm water. Wipe it across the jets a few times then run a cleaning cycle. By the way, you should use plastic gloves as the ink won't wash off your hands. If this doesn't fix the printing, then you'll need a new cartridge as the jets are probably clogged and stuck.
Jan 07, 2011 | Lexmark X4650 InkJet Printer
I have a Lexmark X4650 and about every 2 inches the print is fuzzy/blurred. How can i fix this?
My lexmark printer prints a few lines properly, and then it misses the next few lines, or only partially prints them. How do I correct this problem?
On your inkjet printer, start the Lexmark software,
and run a "print-head-cleaning-cycle", since some (not all)
of the ink-jets that shoot the ink onto the paper are CLOGGED.
Oct 07, 2010 | Lexmark Office Equipment & Supplies
Lexmark x125 prints blank pages.
The printer cartridge could be
1) Out of ink and need to be replaced/refilled
2) The jets at the bottom of the cartridge may be clogged
3) Their could be a bad connection from the cartridge to the pads on the flexible circuit board in the printer.
To try and clean the printer cartridge I have heated a wet paper towel in a microwave oven and set the ink cartridge with the jet are in contact with the hot towel. That sometimes will clear the jets. If you see ink on the paper towel the jets are flowing.
Run the printer software to run the cleaning program and see if you get black bars on the paper. If not there is either not enough ink or there is a connection problem. Sometimes the connection problem can be fixed using a cotton swab in alcohol to clean the contacts on the cartridge and the flexible circuit in the printer. Be very gentle if you attempt this cleaning.
Aug 28, 2010 | Lexmark X125 All-In-One InkJet Printer
What black and white ink cartridge number is used for lexmark x1290?
lexmark X 1290 all in one inkjet printer use Number 16 Black Ink Cartridge 10N0016
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 23, 2010 | Lexmark X1290 All-In-One InkJet Printer
Iron on transfers lexmark x1290
In your printer driver, select the highest dpi setting and the correct paper setting for your type of printer:
Iron-ons are very waxy and the ink may not adhere if not put on thickly. Bellow are some suggested printer settings. For the best results check your printer manual or with your printer's manufacture. CANON: T-shirt transfers.
EPSON: High quality glossy paper or special coated paper, depending on the model.
HEWLETT-PACKARD: High quality glossy paper.
Lexmark: T-shirt transfers.
IMPORTANT: Then set the paper thickness lever on your printer for standard paper. You want the ink nozzles very close to the page.
Jul 23, 2008 | Lexmark X1290 All-In-One InkJet Printer
Lexmark X1290 All-In-One InkJet Printer Logo
304 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
