Question about Brother IntelliFAX 2800 Laser Fax
My fax doesn't recieve faxes anymore, we are still hooked up to the phone line. if i call the fax machine the line just rings and rings
    President:
  • 3,085 Answers
Press start while it is ringing.
Posted on Nov 17, 2009
MY X5650 WILL SEND FAXES BUT NOT RECIEVE THEM
Are you sharing your home phone line with your fax? If so, do you have a voicemail or an answering machine connected in the same line?
If you have an answering machine connected to the same line as the fax, set the answering machine to answer incoming calls before the printer does. Increase the number of rings by a factor of 3 over the answering machine. For example, if the answering machine is set to pick up on 4 rings, set the printer to pick up on 7 rings.
If you have a voicemail feature in the same line as the fax, you may subscribe from your phone service provider for a distinctive ring pattern feature. You can program your printer to have a distinctive ring pattern and phone number for incoming faxes.
Dec 16, 2011 | Lexmark X5650 All-in-One InkJet Printer
Using a toshiba e-studio 190f fax machine, i can not recieve a fax or send a fax. I call the line and it just rings, can youhelp
Make sure you have the phone line plugged in, also make sure it's plugged into the LINE port on the machine. (Ext. is for a extension, i.e. secondary phone for manual dialing)
Also check that the wall jack is functional too, easiest way to do this is hook up a regular phone to the jack and if you get a dial tone you know it's okay.
If the wall jack is getting a dial tone and the line is plugged into the LINE port you may have a bad phone cable, try a different one.
May 31, 2011 | Toshiba Office Equipment & Supplies
How do you set the number of rings on a brother 560 fax machine
Setting Ring Delay:
The Ring Delay setting determines the number of times the fax machine rings before it answers. If you have extension phones on the same line as the fax machine, keep the Ring Delay at a default setting of 4:
1 Press Function/Set, 2, 1.
2 Press < or > to select how many times the line rings before the fax machine answers (00 – 04) and press Function/Set. If you select 00, the line doesn’t ring at all.
3 Press Stop to exit.
Hope that's clear enough :)
Chris (ziraffa)
Nov 26, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Fax will not send or receive
Hi
You need to contact comcast for this issue and get a seperate phone line to which u need to plug in the allinone. This issue may exist most of the Comcast customers.
thx
Jul 09, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Fax\phone line
Here's how to change the ring count...and I'm also providing the link for support and troubleshooting your specific machine on Canon's website...
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=13371
To Change the ring count 1. Press the <Menu> button repeatedly until [FAX SETTINGS] is displayed.
2. Use the [ left.gif] or [ right.gif] to select [RX SETTINGS] then press <OK>.
3. Use the [ left.gif] or [ right.gif] to select [INCOMING RING] then press <OK>.
4. Use the [ left.gif] or [ right.gif] to select [ON] then press <OK>.
5. Use the [ left.gif] or [ right.gif] to select the desired number of rings. Press <OK> then press <Stop/Reset>.
Hope this worked for you!
MaggieB
Feb 22, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Cant send fax
Recieving faxes
  • Plug a regular, non-digital, phone into the fax's phone line and see if you get a dial tone
    • If you do not have a dial tone, seek support from your telephone service provider
  • Dial the fax number from a phone
    • Normal circumstance is that you will have the fax machine pick up and make high-pitched noises
    • If the fax does not pick up, put a regular phone on the fax line and see if the regular phone rings when dialed
      • If the phone rings, answer it and see if there is line noise
        • If the line is clear, call the service number listed on your fax
        • If the line is staticy or unclear, call your telephone service provider
      • If the phone does not ring, call your telephone service provider
Sending faxes
  • Attempt to dial the fax number you are trying to send to from another phone.
    • If you hear electronic noises on the line, the other end has a fax machine on the other end
      • Check to see if you can recieve faxes.
    • If the remote fax does not answer, the problem is on the remote side, contact the recipient
Dec 18, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
Cannot recieve faxes
you need to watch during ringing period need to click ok or press what ever message says.
Dec 03, 2007 | Lexmark X5150 All-In-One InkJet Printer
Faxmachine
CHECK 1.DO YOU GET DIAL TONE ON -ON HOOK DIAL BUTTON OR ON THE HANDSET ? IF NOT PLS CHECK THE PHONE LINE OTHERWISE--- 2.TRY RINGING THE MACHINE FROM OTHER PHONE,CAN U HEAR THE RING ? IF YES ,PLS CHECK WHAT NOS OF RINGS ,THE MACHINE IS SET TO RECEIVE, AS WELL AS SET THE CORRECT RECEIVE MODE , I.E. FAX /TEL/ANS-FAX... 3 IF U STILL DON'T GET FAX TONE WHILE RECEVING ,THEN TELEPHONE LINE CARD SHOULD BE BAD... TRY REPLACING TEH SAME ,SHOULD RESOLVE THE PROBLEM. HAPPY FAXING OMNIPRESENT HAPPY FAXING
Sep 21, 2007 | Office Equipment & Supplies
Cannot figure how to set up Canon MP830 All in One Fax machine with remote answering machine
Cannot figure how to hook up Canon MP830 all in one fax with remote answering machine. I can plug in phone line to send faxes fine but when hooked up in same hole and the phone rings it goes immediately to fax and can't receive phone calls. Maybe i have phone line hooked up in wrong place on my machine. The answering machine is in our master bedroom on the other side of the house. With my last a canon also i had it hooked up to go to fax after a certain amount of rings and it worked fine. That machine got fried by lightening and i replaced it with this machine. If anyone knows what i am doing wrong i really need this fax hooked up all the time for my business.
May 01, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Brother IntelliFAX 2800 Laser Fax Logo
66 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
