Question about Samsung CLX-3175FN Printer
Low heat error. I am assuming it is the fuser unit
    Problem Solver:
  • 13 Answers
It could be the fuser or the power source to the printer. If you have printer attached to a power strip or UPS try disconnecting from that device and see if the issue still exists. If that doesn't work it is probably time for a new fuser.
Posted on Nov 17, 2009
Dell 1600n low heat error
Remove the fuser lamp and put it back in place, it is not heating properly.
Apr 02, 2008 | Dell 1600n All-In-One Laser Printer
177 Fatal Error
Error 177: Thermistor indicates Low Temperature (COLD) Error.
Usualy the fuser has overheated first (error 172/176) and tripped the thermal protection causing the fuser not to heat up anymore.
Normal procedure if a restart doesn't fix it is to replace the fuser unit.
Dec 29, 2010 | Xante CL30 HSE Laser Printer
Okidata c5200n printer 173:FATAL ERROR. What is this? How do I fix it?
In the fuser unit the Heat roller thermister indicates a low temperature error. Replacing the fuser unit will usually resolve this. Fuser units are consumable items bur for an early life failure such as this it may be worth contacting the manufacturer.
Mar 11, 2009 | OKI C5200n Laser Printer
Engine Fuser Low Heat Error
What this means is that the fuser is not reaching operating temperature. The most common reason for this failure is the xenon lamp inside the heat roller of the fuser has burned out. You can verify this by checking for continuity between the two contacts that connect to the lamp with an Ohm meter or digital multi meter.
If the continuity is good, the second most common reason for failure would be the LVPS, or low voltage power supply.
And last, although by far the least common reason for this error is the main logic board.
Have you checked to see if the unit is under warranty? If so, this would be a covered repair.
The part number for the fuser is listed below. Depending on your location and electrical system ( 110 or 220 )
ELA UNIT-FUSER 230V part number :JC96-03239A for use with 230V
ELA UNIT-FUSER 110V part number :JC96-03239B for use with 110V
Other then samsung, you can try a google search, and also an ebay search for the part number and find the best price for the item.
Good luck,
Cory
Nov 04, 2008 | Samsung CLP-510 Laser Printer
"Low Heat Error"
Thats probably the best way to solve the solution. Sometimes if there is a thermistor that is causing the problem that can be serviceable in the fuser unit, that can be replaced instead of purchasing a whole new fuser assembly. It's less expensive replacing the thermistor.
Jul 16, 2008 | Samsung CLP-600N Laser Printer
I have just replaced cartridges and am now getting fuser low heat error.
Yes, either the lamp in the fuser is burnt, the thermistor (heat sensor) on the fuser is burnt, or the low voltage power supply is not providing enough voltage to the fuser lamp. Your safest bet is to replace the fuser.
BUT!!!! The printer itself is let than $150 new with warranty, so if you like this printer I would buy a new one. A fuser will be between $90 and $150 and could be difficult to replace. If you get a service person to replace it you could expect two hours of labour at least which will be about the price of a new printer.
Jun 16, 2008 | Samsung CLP 300 Laser Printer
Low heat error
Low Heat Error
Cycle Power
There is a problem
in the fuser unit.
Unplug the power
cord and plug it back
in. If the problem
persists, please call
for service.
If this doesnt work call the fuser unit needs to be replaced.
Nov 02, 2007 | Samsung CLX 3160fn All-In-One Printer
"Low Heat Error"
You have a fuser error. Try unplugging the power for a minute and plug it back in. If that doesn't work then the fuser unit has a problem.
Feb 03, 2007 | Samsung SCX-4100 All-In-One Laser Printer
Open Heat Error
the thermal switch on the fuser are damaged. my problem is that I don't know the temperature of activation to this. And do not buy a replacement under this conditions. somebody help me.
Sep 27, 2006 | Dell 1600n All-In-One Laser Printer
Samsung CLX-3175FN Printer Logo
175 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
