Question about Toshiba (SD-C2502) Internal DVD Drive
It will not open and the light will not turn on
    Guru:
  • 355 Answers
Change the powerplug of your cd drive
other wise change the power supply card of your cd drive
ok bye.......................
Posted on Nov 17, 2009
Entrance light on Lift Master garage door opener won't stay on when door is opened ?
Light Feature
Activate the Light Feature
  1. Close the garage door.
  2. Start with the garage door opener lights "ON".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn off and come on 10 seconds later.)
Deactivate the Light Feature
  2. Start with the garage door opener lights "OFF".
  3. Press and hold the light button for 10 seconds. (Upon pressing the light button, the lights will immediately turn on and go off 10 seconds later.)
Light Timer
Press the Light button to turn the opener light on or off. It will not control the opener lights when the door is in motion. If you turn it on and then activate the opener, the light will remain on for 4-1/2 minutes. Press again to turn it off sooner. The 4-1/2 minute interval can be changed to 1-1/2, 2-1/2, or 3-1/2 minutes as follows:
  1. Press and hold the Lock button until the light blinks (about 10 seconds).
  2. A single blink indicates that the timer is reset to 1-1/2 minutes.
  3. Repeat the procedure and the light will blink twice, resetting the timer to 2-1/2 minutes.
  4. Repeat again for a 3-1/2 minute interval, etc., up to a maximum of four blinks and 4-1/2 minutes.
Oct 20, 2017 | Building Materials
The interior light on the doors of the car will not turn off. how do i turn them off? happens when the car is off.
most cases one of 2 things you turned the dash lights on to the point where the lights stay on.....or there are small switches that opens and makes contact to turn the lights on when the doors are open when you shut the door the contact is released and it turns the lights off. Some the times the wire can come disconnected and leaves an open switch and the doors thank that they are open therefore the light stays on it should have only one screw to hold it in place, you can gently pull this out and find out if the wire is no longer connected. Or if the door plunger gets broken off the door cannot turn the switch off because it is broken.
Mar 05, 2016 | 1998 Toyota Sienna
Craftsman 315 MHz 1/2 hp garage door opener - when it's open the light keep turning on when somebody passes by?
This behavior is a feature of the Security+ door openers. It can be disabled via the control console:
Lights will also turn on when
someone walks through the open garage door. With a
Premium Control Console, this feature may be turned off
as follows: With the opener lights off, press and hold the
light button for 10 seconds, until the light goes on, then
off again. To restore this feature, start with the opener
lights on, then press and hold the light button for 10
seconds until the light goes off, then on again.
Those are instructions from page 30 of the manual of a similar, if not the same, opener:
http://www.searspartsdirect.com/partsdirect/user-manuals/137707/13953985DM-Craftsman-Parts-GARAGE+DOOR+OPENER-manual?pathRender=fromManualTabPage
Apr 29, 2014 | managemylife.com
Interior lights do not turn off when car is turned off
have you set the light switch to the courtesy light position , with the ignition on turn light switch so light is on then turn switch so light is off ,open door if light comes on that is the courtesy position if does not close door turn switch to the last position then open door light should be on close door light off,TURN IGN OFF EXIT AN LOCK VEHICLE INTERIOR LIGHTS WILL STAY ON FOR A FEW SECONDS THEN SLOWLY DIM .watch them before leaving
Mar 29, 2014 | 2004 Jeep Grand Cherokee
My light doesnt come on when i break the sensor....and my learn light blinks none stop
Random blinking of the learn light is normal.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Feb 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
On security + models, the lights should come on when someone walks through the open door. According to the owners manual, this feature can be turned off, but I can't get it to work at all. Can anything...
Oct 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
I cannot get the overhead light to come on when I walk past the sensors. It used to come on. The bulb is not burned out. Also the indicator light on the opener keeps flashing.
Jan 25, 2010 | Sears Craftsman LiftMaster Chamberlain...
Security light will not work
You must have a three function wall switch. This means in addition to a button that opens and closes the door there are two other buttons on the same wall switch. One is marked LIGHT and the other is marked LOCK.
To have your lights come on automatically when you walk into an open garage you must START with the lights ON. To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
Aug 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Interior lights won't turn on when door opens
you have a bad drivers door latch, the micro switch inside is not telling the computer that the latch has been opened which would normally mean the door is open.
Mar 31, 2009 | 2000 Volkswagen Jetta TDI
Toshiba (SD-C2502) Internal DVD Drive Logo
56 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
