Question about Samsung LN-S4051D 40 in. LCD Television
My tv powers on but nothing shows up on the screen.
    Scholar:
  • 56 Answers
If the red LED blinks and you hear a clicking -
This is a comon problem with the Samsung LCD HDTV on the Power Board.
You can repair or replace -
Faulty parts on PS board , bad press for Samsung.
When checking the capacitors, If they are slightly rounded on the top where the X is, the cap is defective.
Because the Samsung LNS4051D would not turn on and the power
LED would blink 4 times and the relay would click and this
would repeat again and again. I replaced power supply board
parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors,
three had their tops bulged up slightly that I missed on
initial visual inspection. After seeing the reports of
problems with these caps on
http://www.fixya.com/support/t1336881-will_not_turn_or_off ,
I replaced them with Radio Shack part 272-1032, 1000 uf, 35v.
They are slightly bigger, but fit OK. TV is working fine now.
Cost was 4 x $1.59 = $6.36 plus the time. I saved between
$100 to 300 in the process of either replacing the board or
getting the unit serviced. If you are not comfortable
replacing components which means using a soldering iron, you
can replace the power circuit board, available from
www.Samsung.PartStore.com.
Some UTube showing the problem and fix -
http://www.youtube.com/watch?v=tK7zFBBU6p4&feature=related
http://www.youtube.com/watch?v=Mm51C_RDIZE&feature=related
http://www.youtube.com/watch?v=BNHHrgX_6cs&NR=1
Posted on Jun 01, 2010
Screen
Posted on Nov 17, 2009
42PM3MV turns on, but displays nothing on screen
some tv'srequire a channel button to be pressed or the on/off button on the remote to function try this , if you have then i'm stumped sorry.
Feb 15, 2012 | LG 42PM3MV 42 in. PLASMA TV
Power comes on but it only shows a blank screen. screen shows nothing at all no menu, nothing. tv works fine.
Make sure the video/audio cable is plugged in correctly. Red cable into red socket, yellow into yellow and white into white. It is easy to put these cables in the wrong socket by accident and will cause no image to appear on your screen.
Jun 12, 2011 | Video Game Consoles & Games
My toshiba l500-02h is only showing blank page with booting.
Hello, Does it sit there and do nothing? Sometimes all that is needed is the battery pulled (disconnect power cord as well) Press and hold the power button down for about 5 seconds. Put battery back in and connect power cord. Now try booting. If nothing shows on the screen, the next step would be to connect an external monitor or TV (if you have one) to the VGA or HDMI port. If a picture shows on the monitor / TV but still not on the laptop, you may have a burnt out display... which is expensive to fix. You may find some good prices for screens on dbay.
Chris
May 11, 2011 | Computers & Internet
When unit powers up - nothing shows - menu rolls
resit your projector to factory default. if problem occur clean the entire projector. or change your projection bulb.
Oct 07, 2009 | Christie LX45 Multimedia Projector
I power on my Precision TV power light comes on but nothing shows
check the power supply
check the horizontal transistor
Jul 06, 2009 | Apex Digital PF2720 27" TV
TV repair man said that the regulator BSC 62A is damage. When apply power to TV on the power light on the front of the TV comes on but nothing shows on screen. Whats wrong?
Jul 06, 2009 | Televison & Video
Vizio p42hdtv10a
Bad interface circuit or power supply. Needs servicing..
Jun 13, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
VS-45603 we have power but nothing else will show up on screen.
I would suspect bad solder connections on the convergence IC's caused one to short out a blow one or more pico fuses, thus causing the set to go into shutdown so as to stop further damage to the set. The TV will need to be seen by a profesional to confirm or deny this.
Dec 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Samsung LN-S4051D 40 in. LCD Television Logo
215 people viewed this question
Jerry Greenberg
Jerry Greenberg
