Question about Dryers
I have a maytag dryer model number PYE1000AYW I am changing the belt and have no idea how it goes back on and can not find any diagram to help, PLEASE HELP!!!!
  • 1 more comment
  • hbrat77 Nov 17, 2009
    Okay I believe that I have done all this and there is still not enough tension on the belt, Do you know of a diagram somewhere so I can make sure that I have it on there correctly.
    Thank you you were right it was on the wrong side THANK YOU so much for all the help finally we can dry clothes again.
    Thank you so very much for all your help flatech. Your information was perfect. Thank goodness to I was tired of going to laundry mat.
    Scholar:
  • 111 Answers
Don't panic my friend, we have all been there before(Well most of us).
At the bottom you will see a pulley which is usually above the motor.
I usually put the belt around the drum first. Make sure its lined up where it was before, or close to the line.
Then squeeze the bottom of your belt together at the bottom and pull both parts of the belt under the pulley, then attach it to the motor pulley.
The first pulley you may have to pull it back a little to stretch it to the motor, Its not easy and you may get a little frustrated, but hang in there and give it a few tries, you will evrntually get it on.
Once you do then turn it clockwise a few turns until it all lines back up.
Good Luck!
Thank you for using FixYa!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
Posted on Nov 17, 2009
  • Michael McQuay
    Michael McQuay Nov 17, 2009
    You may have the belt on the wrong side of the pulley, Have to remove it from the motor and put it on the other side of the tension wheel.
    When it is on correctly you will feel the tension against the belt, and if you can turn it clockwise then you have it on correctly.
    My first time was very frustrating and bel;ive me i understand, just have to look at it a few times until you get it properly on.
    Thanks for using FixYa!
  • 6,784 Answers
Hi. click here to access a diagram for your unit.
I need a diagram of how the drum belt is installed on a maytag centennial dryer. Mine came off and I don't know how to put back on.
Hi c ellerts..
Here is the picture of the routing of your Maytag..
You can get this at the following wepage
Please take time to rate me thumbs up
http://www.expertappliance.com/dryerbeltconfiguration.html
Sep 12, 2011 | Maytag Dryers
Trying to replace the dryer belt forgot how the old one came off b/c it broke. not sure how to get it back on to the pullys. maytag dryer model de7600.
This link is a listing of diagrams of belt configuration on various brand dryers the diagram for how the belt goes on the motor/idler pulley on the Maytag brand is going to be diagram E
http://www.repairclinic.com/Dryer-Belt-Diagrams#DiagramE
GENE
Aug 31, 2011 | Maytag Dryers
Need SDE305DAYW dryer belt routing diagram. Please help
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Scroll down and you'll find the maytage diagram. There are many, but it's about half way down.
Good luck, it might help to have a buddy help for an extra set of hands.
Mike
Aug 04, 2011 | Maytag PYE2300AY Electric Dryer
I need a diagram on how to route the belt on a maytag atlantis dryer model number mde7600yw and also a diagram of the tensioner spring for the tension pulley
Hi and welcome to FixYa, I am Kelly
The flat side of the belt goes against the drum and the routing diagram can be found here:
If you need more assistance after viewing the diagram and attempting to install your belt without success, just respond here and I can help you.
Thanks for choosing FixYa,
Kelly
Mar 16, 2011 | Dryers
Cant figure out how dryer belt goes around pully and moter
Go to repairclinic.com and click on the "Get Repair Help" link. Select the "Dryer" category, followed by "Click here for a dryer belt installation diagram". There are numerous illustrations that you can use to assist you with the proper routing of your dryer belt. If the model number is correct, refer to diagram H. I hope this helps you.
Feb 16, 2011 | Roper REK2950W Electric Dryer
Maytag Dryer model PYE1000AYW runs fine no heat
Hello & Welcome to FixYa
As everything in your dryer is working fine apart from it heating properly so the recommended repair will be thermal fuse/thermostat replacement. However, you can also test its continuity before replacement. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Dryers
I am replacing the drum belt and I am not sure how it goes on. Can you send me a picture
Repairclinic.com has an extensive list of dryer belt diagrams. Just go the site and click on the "Repair Help" link. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. The illustration for Maytag dryers is diagram E. For your convenience, here is a direct link:
http://www.repairclinic.com/0079.asp#DiagramE
If you have questions, or if your dryer differs in design, please post back with a MODEL NUMBER. I hope this helps you.
Jul 11, 2010 | Maytag Dryers
Need to change the belt on my Maytag Performa Dryer
The belt is a 341241, a pretty standard belt. To install it you must get the front panel off. Do this by using a putty knife: 549402b.jpgUse this hady DRYER BELT ROUTING guide
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 26, 2009 | Dryers
PYE1000AYW Maytag dryer
dont know if this will help or not ribs go up .. flat part of belt goes against drum this has a crapping diagram of curve of belt http://www3.sears.com/imaging/ImagePageJava.shtml?productTypeID=0151200&brandID=3048&modelDesc=ELECTRIC/GAS%20DRYER&modelNumber=PYE1000AYW&documentID=M0412160&documentTypeID=PLDM&documentClassCode=PV&titleType=TUMBLER&titleID=00004&
Aug 26, 2007 | Maytag PYG3200 Dryer
Dryers Logo
Top Dryers Experts
