Question about HP Computers & Internet
Iexploe has caused an error in mshtml.dll ieplore will now close, how can i fix this
    Brigadier General:
  • 10,406 Answers
If the problem happens with only one specific web-site, then avoid that web-site.
Otherwise:
Click Start
Click Control Panel
Click Classic View
Click Add/Remove Programs
Select Internet Explorer
Click Remove
This will "downgrade" your computer to an older version of Internet Explorer. Try the web-site again.
In a day or two, Windows Update will "upgrade" you, by installing the latest version of Internet Explorer. Perhaps, this "re-install" will fix the "error".
Posted on Nov 17, 2009
Canon i350 not recognised by any applications
This is quite a long one so be prepared: Assuming you use IE7 on Win XP FIRST: Are you using a Packard Bell machine or do you have "Surfairy" installed? If so you need to remove Surfairy. To see if it is present if you are not sure use the windows search facility to look for surfairy in my computer. It would also be usefull if you could post the exact text (if any) contained within the Script Error window. Second: pen a new notepad session, to be called IE_fix.cmd, and copy/paste the below: regsvr32 urlmon.dll regsvr32 Shdocvw.dll regsvr32 Msjava.dll regsvr32 Actxprxy.dll regsvr32 Oleaut32.dll regsvr32 Mshtml.dll regsvr32 Browseui.dll regsvr32 Shell32.dll regsvr32 Ole32.dll Save the file, then double click IE_fix.cmd and answer the prompts. Ignore any error messages. Reboot and test. If the problem remains follow the method below Start, Run, SFC /Scannow (Have your XP CD Handy. Note that this command does not give feedback on the repairs it makes. The repairs are listed in your Event Logs.) The error may be linked to a missing/corrupt system file in XP that IE 7 exposes. A repair reinstallatiion of XP will fix it, but the above steps are less drastic.
Jul 11, 2007 | Canon i350 InkJet Printer
IE 8 has mshtml.dll unhandled exception error
Please try reinstalling Internet explorer. You could also try using a ergistry cleaner such as CCleaner which is availible from filehippo.com. Clean the registry errors out and that might fix the problem without reinstalling.
Mar 02, 2011 | Microsoft Internet Explorer 8
The hyperlinks are not working in my emails and in some other websites but they do work in google.
If you are using Outlook to browse yor emails here is the way to fix the hyperlink problem:
Follow these steps:
  1. Click Start, click Run, type the following command in the Run dialog box, and then click OK: regsvr32 urlmon.dll
  2. Repeat step 1 for each of the following commands:
    regsvr32 mshtml.dll
    regsvr32 shdocvw.dll
    regsvr32 browseui.dll
    regsvr32 msjava.dll
Dec 05, 2010 | Microsoft Windows XP Home Edition for PC
Tried to startup and computer shuts down citing ''Fatal Error''
just try to boot the system in safe mode and run thse chkdsk command.
Jan 15, 2010 | Computers & Internet
Internet Explorer 8 fails to connect
Run the following command. It should help
Click on start > run and type in the below mentioned commands one by one.
regsvr32 urlmon.dll
regsvr32 hlink.dll
regsvr32 msjava.dll
regsvr32 mshtml.dll
regsvr32 jscript.dll
regsvr32 vbscript.dll
regsvr32 softpub.dll
regsvr32 wintrust.dll
regsvr32 dssenh.dll
regsvr32 cryptdlg.dll
regsvr32 gpkcsp.dll
regsvr32 wucltui.dll
regsvr32 wups.dll
regsvr32 initpki.dll
Mar 30, 2009 | Microsoft Internet Explorer 8
Videos
try this works for me
Fixing Internet Explorer Javascript Links
Sometimes in IE when you try to open links that open in new windows, they don't open. At the bottom left of the IE window you will see a yellow triangle which indicates its a Javascript problem.
  1. Start » Run » Type regsvr32 /s URLMON.dll
  2. Then do the same but change the DLL names to the following:
    scrrun.dll
    Msxml.dll
    Mshtml.dll
    Shdocvw.dll
    Browseui.dll
    Msjava.dll
    Actprxy.dll
    Jscript.dll
    Vbscript.dll
    oleaut32.dll
  3. Restart IE and your links should be fine.
  4. Alternatively you can copy this in to a text file and save it as a batch file (.bat file)
    regsvr32 /s scrrun.dll
    regsvr32 /s Msxml.dll
    regsvr32 /s Mshtml.dll
    regsvr32 /s Shdocvw.dll
    regsvr32 /s Browseui.dll
    regsvr32 /s Msjava.dll
    regsvr32 /s Actprxy.dll
    regsvr32 /s Jscript.dll
    regsvr32 /s Vbscript.dll
    regsvr32 /s oleaut32.dll
  5. This will re-register all the DLL files. All of the above are used by IE.
Oct 11, 2008 | YouTube Videos
Can't print from My Documents or Emails. "Internet Explore Script Error" appears. Error: Class doesn't support Automaation.
First, see if there is a newer version of the print driver and install that.
If that doesn't work, you may need to refresh the relevant DLLs. Go to START > RUN and type the following lines, one at a time, and click OK.
regsvr32 Urlmon.dll
regsvr32 Mshtml.dll
Remember, one at a time, so you are repeating the procedure 6 times.
May 26, 2008 | HP Office Equipment & Supplies
Invalid syntx error
The cause of this issue
CAUSE loadTOCNode(1, 'cause'); This behavior may occur for one or more of the following reasons: • The (Default) value setting in one or more of the following registry keys points to an incorrect location for the Urlmon.dll file: [HKEY_CLASSES_ROOT\CLSID\{79eac9e0-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f1-baf9-11ce-8c82-00aa004ba90b}\InprocServer32] [HKEY_CLASSES_ROOT\CLSID\{79eac9f2-baf9-11ce-8c82-00aa004ba90b}\InprocServer32]This Behavior May Occur if you install a customized version of Internet Explorer that was created with the Internet Explorer Administration Kit (IEAK) version 5.01 Service Pack 1 (SP1), 5.5 SP1, or 6.0. • The following registry key is missing or damaged: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046} • One or more of the following files is missing, damaged, or improperly registered: • Urlmon.dll • Mshtml.dll • Actxprxy.dll • Oleaut32.dll • Shell32.dll • Shdocvw.dll
RESOLUTION loadTOCNode(1, 'resolution'); To resolve this problem in Internet Explorer, follow these steps: 1. Quit all programs that are running. 2. Click Start, and then click Run. 3. Type regsvr32 urlmon.dll, and then click OK. 4. When you receive the "DllRegisterServer in urlmon.dll succeeded" message, click OK.If this does not resolve the problem, repeat steps 2 through 4 for each of the following files (in step 3, replace Urlmon.dll with each of the file names below): • Shdocvw.dll • Actxprxy.dll • Oleaut32.dll • Mshtml.dll • Browseui.dll • Shell32.dll Windows XP and Windows 2000 only loadTOCNode(3, 'resolution'); Restart the computer to enable the changes to take effect.
If the problem is still not resolved, verify that the following registry values are present and correct: HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}
Value: IDispatch
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid
Value: {00020420-0000-0000-C000-000000000046}
HKLM\SOFTWARE\Classes\Interface\{00020400-0000-0000-C000-000000000046}\ProxyStubClsid32
If the problem is still not resolved, reinstall Internet Explorer. If you are using the version of Internet Explorer that is included with your operating system, reinstall or repair your operating system.
Thanks
Riz
Mar 21, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
