Question about Motorola Mobility W375 Cellular Phone
How to get the photos off the Motorola W375 phone camera onto the computer using the supplied usb cable?
I lost my drivers. it s not getting connected to pc
HOWTO_Connect How to connect Motorola W375 to a Windows computer Introduction¶ This document describes how to connect your Motorola W375 to your computer in order to use it as a modem, or to administer it with Motorola W375 Manager software.
Connecting¶ To connect your motorola W375, follow the next steps:
  • Download and uncompress Motorola W375 Driver from this site.
  • Connect your W375 to your computer with its lid closed.
(You can also connect the device with its lid open, and choose "not" when it asks for permission to connect as an storage device)
  • When Windows asks you for a driver, select Motorola W375 driver folder.
This way, the next time you connect your mobile phone closed, your computer will recognize it as a new communications port and you are ready to use it with Motorola W375 Manager. If you open this "COM" port with a terminal emulation software (i.e Windows Hiperterminal) and type "AT", the mobile phone will respond you with an "OK" string.
Using it with Motorola W375 Manager¶ To use your mobile with Motorola W375 Manager, simply connect your mobile phone closed and then, start Motorola W375 Manager software.
Using it as a modem¶ To use your mobile phone as a modem, install "Standard 19200 Modem" driver and select the communications port associated to your motorola W375.
About Motorola W375 driver¶ Motorola W375 driver is basically the same driver known as Motorola USB Charging Driver. You can download Motorola USB Charging driver from motorola US support web site for Motorola W375. If you try to use Motorola USB Charging driver directly with your Motorola W375, device type will not be recognized, but if you change device ID from "USB\VID_2811&PID_0702" to "USB\VID_22b8&PID_4061", this usb charging driver will become completely compatible with wour Motorola W375 mobile phone. The driver you can download from this site, is exactly a Motorola USB Charging driver with the mentioned modification.
Dec 07, 2010 | Motorola Mobility W375 Cellular Phone
Need help
you must need the data cable for your model.......
Sep 05, 2009 | Motorola Mobility W375 Cellular Phone
How do you download Photos from W375 to computer
FIRSTLY YOU NEED TO HAVE A USB DATA CABLE OR BLUETOOTH FOR THE PHONE THEN GOTO SONY WEBSITE AND DOWNLOAD PCSUITE AND THAT WILL ALLOWYOU TO SYNC TYOUR PHONE, ADD IMAGES, MESSEGES ETC
Nov 10, 2008 | Motorola Cell Phones
Motorola 375
its simple, just open your phone[dont let it closed] and plug your cable..
then your screen will shows something, and your comp will appear to install new device, just cancel it..
then go to 'my computer' and you might see your phone drive there
Aug 25, 2008 | Motorola Mobility W375 Cellular Phone
How do I connect my Motorola w375 to PC
try downloading the motorola usb drivers and installing them.
i would try that first.
you could also get motrola phone tools software which comes with the drivers and can transfer the photos from your phone
Apr 12, 2008 | Motorola Mobility W375 Cellular Phone
Driver download
thank to raysagem......when i click the "yes" in screen to become storage cellphone in my w375 it works....thanks again
Jan 08, 2008 | Motorola Mobility W375 Cellular Phone
Can't download photo's onto computer
Are you connecting your phone as a Mass Storage Device?
  1. From the home screen, attach one end of the Motorola Original Enhanced USB cable to your phone and the other end to a USB port on your computer.
  2. On your phone, press Yes to use the phone as a portable USB storage device.
    Note: When connected as a storage device the phone cannot perform regular phone activities. Disconnect to resume normal operation.
  3. On the PC, open the My Computer window and find where your phone displays as a Mass Storage icon.
    Double click the Mass Storage Device icon.
  4. Drag and drop files between your computer and phone.
  5. When finished, remove the phone safely from your computer. Right click the "Safely Remove Hardware"
    icon at the bottom of your computer screen, then select "USB Mass Storage Device" and click Stop.
  6. Select USB Mass Storage Device and click OK.
    Now it is safe to disconnect the cable. When the cable is disconnected, the phone restarts
Jan 02, 2008 | Motorola Mobility W375 Cellular Phone
Unable to download photos from motorola w375
you will need motorola phone tools in order to transfer photos and music to your phone. and for information, your phone can only have 1.5mb memory therefore it wont hold much pictures
Dec 27, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
How to browse my motorola w375 in my pc using the usb cable?
use this link-----         idenphones.motorola.com/iden/support/showSoftwareDownloads.do
Oct 05, 2007 | Motorola Mobility W375 Cellular Phone
Motorola Mobility W375 Cellular Phone Logo
61 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
D. E. Hev
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
