Question about Polaroid FLM-323B Television
TV has power, the blue light is on but no pic. All the caps look good and i've already replaced the Z9 diod. Help me please.
  • 557 Answers
Hold a flash light on an angle to the screen see if you can see the picture in the backgroung. If you can bad inverter.
Posted on Nov 17, 2009
Intermittent picture. Lights on circuit blink when starting up. Often sound, no pic. Blue and blinking yellow for 2 or 3 tries, then picture. Sometimes only blue with no sound or pic. Ballast?
Ballast Board! Go to Encompass Parts Distr online find out what your Part# is! or Call 1-800-638-3328 also try UED 1-800-648-6657 This TV has alot of fuses over 20 of them!You didnt say have you replaced Lamp thats what goes first 9/10 unless you get power surge or Bad capacitors on the power supply Board caps are bad if they are puffed up on top 1000uf25v caps!
Nov 23, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
The TV no longer works. The red power light on the TV no longer shines as it did when the TV was off. Any idea what the problem might be and if it is worth repairing? The TV is only 5 months old.
D10 is shorted. HER304 in middle of Power supply board near large electrolytic cap. Replace with Radio Shack 276-1144 3A 400PIV Diode. PLEASE BE CAREFUL WITH HIGH VOLTAGE PRESENT ON POWER SUPPLY BOARD. UNPLUG POWER CORD!!! OBSERVE PROPER POLARITY WHEN REPLACING DIODE-LOOK WHERE THE BAND IS.
PS- I just fixed this same problem this morning on same model.
Jul 30, 2009 | Memorex MLTD2622 26 in. LCD TV
Turned TV on with remote, circular indicator went
Please call Memorex customer service at 800-919-3647.
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If the TV is less than one year from the date of purchase, it is still under warranty. Call the number above so that you can have the unit repaired.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 17, 2009 | Memorex MLTD2622 26 in. LCD TV
I have a VS-526r,VE-526r television and the blue bulb appears larger than the other colors. Any suggestions?
is uot of focus try to adjust or need blue tube replaced ptv is old model tubes no longer available
Jun 12, 2009 | Televison & Video
No longer turns on
It's well worth replacing the capacitors, but this problem can be caused by a short on the power supply (Which is what the caps do). Most shorts that arise in power supplies are result of a shot transistor or diode and of course the electro caps. Check these while your changing the caps.
Good luck with it.
May 25, 2009 | Televison & Video
Green tint and psychedelic color swirls in picture
I have a good but with green tint on a polaroid tv model number 64SX505Y-DC02
Dec 28, 2008 | Polaroid FLM-3232 Television
IS-LCDTV32 32 will not stay powered on
Went dead? no power light? if you had no lights at all its probably the power supply, if you had a red light then I would go with the main board. Disconnect the lcd panel from the main pcb and inverter and see if your blue light stays on. If so you have a bad panel.
Aug 21, 2008 | Insignia IS-LCDTV32 32 in. Television
Polaroid FLM-323B Will not turn on
Polaroid FLM-323b No power,No led light, checked the fused and the fuse is good?
Can't find any bad Caps? Well I spent some time, well alot of time trying to figure out what's wrong and finally did.
The problem is a diode on the power board location Z9 Part # ( P6KE350A )On some boards it's the diode and the capacitor right next to it part # ( R 331K 1KV )
If this works Please donate Paypal Is12ok@aol.com anything helps Ive spent well over a weeks time and count less hours trying to figure out what was wrong.I have included some pics to try and help.
Thanks Z28r2fast4uc144496.jpg18b1844.jpg27931f3.jpgdb4f9c3.jpg f53556c.jpg 7eeee7c.jpg
Oct 21, 2007 | Polaroid FLM-323B Television
Loud pop and picture is no longer available.....
blown resistor (42ohm) replaced this and it imediately blew it clearly shows that there is a short circuit in your tv. if you are a tech person please proceed as follows. 1 isolate power supply from hor.output section. 2 now check power supply section.i.e. switching tran., cap..diode etc. 3 if it becomes ok check power supply output. 4 if output is ok then check hor. output section.i.e. h.out tr.,cap& diode in eht winding. 5 check print near eht. 6 at finally eht. 7 see every thing is normal now. now reconnect power to hor.section. put on tv. good luck.
Sep 24, 2007 | Philips 7P6041W TV
Polaroid FLM-323B Television Logo
173 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
