Question about Samsung BD-P1400 Blu-Ray Player
Hi there i have problem my dvd player and the
Hi there i have problem on my samsung dvd player. When I insert a dvd disc in the dvd the voice works, but there is no picture showing. What is wrong with it? and how can I fix it?
  • 1003 Answers
SOURCE: DVD player says "no disc"
replace the player because laser lens is probably burnt out.
you can get a new player for 30 bucks at target or walmart
Posted on Jan 15, 2008
  • 13 Answers
SOURCE: SAMSUNG SV-DVD440 Combo
how old is the player, it sounds like the lazer has gone down if it reads cds and not dvds
Posted on Feb 10, 2008
SOURCE: my samsung dvd-hr735 now region free wont let me record onto dvd
Could be your using the wrong disc.
type is DVD-R where - is a minus as distinct from DVD+R
Posted on Apr 07, 2008
VOTIT
  • 2071 Answers
SOURCE: My dvd player Samsung DVD-R135 will not read any disc
Manually cleaning the lens
To locate the laser lens, look around the door or drawer of the DVD player and you will see a small circular disc, which is often called the turntable or disc platter. Right off the edge of the platter you should see a small clear lens. There are some manufacturers that have had problems with the lens, depending on the age of the unit. In these problem players, moving the unit to a different location, turning the unit upside down, or sometimes even without moving the unit, the lens can become detached from the laser assembly and floats around inside the unit. You can re-glue it back with a little crazy glue, BUT it must be perfectly centered, and without getting any glue on it. So, if you don’t see the plastic lens, but instead see the laser pick-up assembly, look around for the lens inside the unit and glue it back on.
To clean the lens you must use very little pressure. Take a cotton swab and barely moisten it with plain, non-scented, or oily type alcohol. In a swirling motion, very gently rub the lens until you’ve covered it entirely. Then repeat using the dry end.
If the cleaning didn’t help, don’t despair just yet. You can see if there’s a problem elsewhere in the unit by using a few simple tricks and tips.
First thing you want to see if the unit’s laser is in good working order. This method isn’t foolproof, but most of the time works admirably. When you insert a disc, see if you can look up underneath where the disc sits on the turntable. Observe the laser lens going up and down. If the lens is trying to focus, that’s good! After a few seconds of the lens trying to focus, the platter should start to spin. On almost every CD/DVD unit I've encountered, the unit won't spin unless the laser has properly focused on the surface of the disc. If the unit spins up and and then shuts down, you should check and make sure the laser pick-up assembly slider mechanism is working without any obstructions and that the small chrome rail that it slides on is slightly greased. Don’t go overboard with the grease though, as too much can cause all sorts of problems.
The slider mechanism, depending on the age of the unit and the manufacturer, consists of the small chrome rail, a drive motor, a small gear assembly, and (in some units) a small belt that drives the slider unit via the motor. This small belt causes all sorts of problems. If the belt is broken or slipping, it can cause skipping, dropouts, or simply no start up at all. Also, if the belt breaks in the middle of the disc, the drive mechanism gets hair or dirt wrapped up into the gears, or the pick-up assembly doesn’t return to the start position (called home), the unit will (99% of the time) refuse to release the disc, causing it to become stuck inside the unit. There’s a little micro or leaf type switch located at home position that sometimes gets dirty or breaks and, causing this problem also.
If the disc starts to spin slowly and doesn’t come up to speed, the spindle motor that’s attached to the turntable platter is a common problem. There could also be a problem with the spindle motor driver controller IC or the power supply regulator that supplies voltage to the driver IC. If the disc starts to spin and then spins really fast, or stops and starts to spin backwards, your problem is the laser pick-up assembly or the servo control circuit. If you continue to have problems after cleaning and checking the other things listed above, you may have a problem with the player's alignment. Of course, one of the problems you'll face checking alignments on a DVD/CD player is that you’re going to need to use an oscilloscope on most of them. If you have the proper tools and equipment, the first thing to look at is the RF pattern of the unit while its playing. It should be a sharp and clear pattern. If it's dull and smeared, then the laser could be weak.
Also, in these units are very critical alignments called the focus/tracking gains and offsets. When these alignments are off, it can often cause intermittent troubles. As the unit ages and parts change value, so do these alignments, and will need to be checked. In my time as service technician repairing DVD/CD players, 65% of the laser pick-up assembles I have tested were good and only needed a small adjustment. Today's technology makes it unfeasible for a shop to hook up a DVD/CD player, and even some recorders, to their equipment and make these adjustments because of the cost involved.
Hope this may help;
Regards,
VOTIT
DON'T TO FORGET TO RATE
Posted on Sep 06, 2008
likha
  • 790 Answers
SOURCE: Dvd recorder can't read the disc.
Hi
Try to cleaning the pick up lens with 100% cotton.
Thanks!
Posted on Dec 05, 2008
'No disc' message on Samsung DVD home theatre system
hello,
the problem the disc is samsung DVD home theatre is having is the lense that is weak. if yo replace the lencse then it wold work properly.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
Sony DVD player reads no disc after inserting disc?
Its due to faulty Laser Lens/head. Try cleaning it by cleaning CD. If still the problem persists, contact near by service center.
Mar 13, 2009 | Sony DVP-NS715P DVD Player
Hi
Thanks!
Dec 04, 2008 | Samsung DVD-R135
I have a Samsung BD-P1000 Blu-Ray Disc Player that will not play Blu-Ray discs rented from BlockBusters in Calgary, Alberta, Canada. To Date, of all my 100 regular DVD, and approximately 25 owned Blu-Ray...
BD-P1000 Update Solution
The solution that worked for me: I went to www.samsung.com/ca and downloaded the Samsung BD-P1000 player's firmware update to my desktop. When opened, I was directed to"burn" a DVD on my computer. I then inserted the new DVD in my Blu-Ray player. The player automatically checked and confirmed player model number and registration and uploaded information from the DVD and the update was complete. The BD-P1000 then flawlessly played the rented Blu-Ray disc of "The Scorpion King".
Thank You Samsung!
Nov 27, 2008 | Samsung Televison & Video
Dvd
The Samsung HT-Z310T is a DVD player, not a recorder, that is why you are getting an error when inserting a blank disc
Sep 01, 2008 | Samsung HT-Z310T Theater System
Feb 09, 2008 | Samsung SV-DVD440 DVD Player/VCR
Jan 15, 2008 | Samsung DVD-V4600 DVD Player/VCR
two DVD player with same problem. I think they are disposable. :(
Dec 25, 2006 | Samsung DVD-V8500 DVD Player/VCR
Samsung BD-P1400 Blu-Ray Player Logo
14 people viewed this question
Jerry Greenberg
Jerry Greenberg
