Question about Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S119 No boot
I have a L25-S11 that powers on with the Toshiba splash screen and asks for either F2 or F12. The hard disk drive light is always on but it never boots and either key will take you to the next level...i.e. entering setup or entering multiboot menu..please wait. Never goes anywhere...is frozen.
I've tried with hard drive removed...same results. Have tried with a known good drive from another laptop (XP system) with the same results.
No recognition of the DVD drive a all..won't open drive. Machine is 2 years old...no problems until this. Worked fine in morning.
  • Anonymous Feb 23, 2008
    I have a L25-S119 that powers on with the Toshiba splash screen and asks for either F2 or F12. The hard disk drive light is always on but it never boots and either key will take you to the next level...i.e. entering setup or entering multiboot menu..please wait. Never goes anywhere...is frozen.
  • Anonymous Nov 06, 2008
    I forgot Toshiba satellite A305-s6845 Supervisor password
Had the same problem turned out to be the DVD drive. Apparently it won't boot if the DVD drive is not recorgnized.
Posted on Feb 21, 2008
It sounds like you have a dead BIOS.
Posted on Jan 11, 2008
  • 520 Answers
Reset bios to default try installing fresh system
Posted on Jan 10, 2008
My toshiba satellite l25-s119 turns on but the screen is blank?
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 27, 2011 | Toshiba Satellite L25-S119 Notebook
My laptop won't start... please
Not sure but it sounds like the hard drive is causing the problem. Lap tops are set up so that any problems with them they shut down, and a bad hard drive will shut you down the way you are describing. The only test i know for this is to remove the hard drive and see if you can get the computer to at least boot. If you can with no hard drive then it usually means the drive has failed. Not sure if this will help, but hope it helps.
Jun 16, 2010 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S119 laptop-No image on screen but the fan powers up when the power is turned on. The Power button illuminates then turns off but the fan continues to run.
well your leaving a lot to the imagination..is the hard drive light working..plug it into a external monitor then boot it..then we can go from there..
Feb 18, 2010 | Toshiba Satellite L25-S119 Notebook
How can i recover my laptop to factory settings?
Applicable Models: Satellite L15-S104, L15-S1041, L20-S310TD, L20-SP231, L25-S119, L25-S1194, L25-S1217, L25-S1213, L25-S1215, L25-S1216, L25-S1196, L25-S1211, L25-S1214, L25-S1212, L25-S121, L25-S1193, L25-S1192, L25-S1195, L35-SP1011, L35-S2366, L35-S2316, L35-S2206, L35-S2194, L35-S2174, L35-S2171, L35-S2161, L35-S2151, L35-S1054, P100-ST7111, P100-ST9212, P100-ST9712, P100-ST9742, P100-ST9772, P100-ST9762, P100-ST9752, P100-ST1072, P100-ST9732, P100-ST1071, P100-ST9412, P100-ST9612, P100-ST9012, P100-ST7211, P105-S921, P105-S931, P105-S9339, P105-S9337, P105-S6227, P105-S6217, P105-S6134, P105-S6124, P105-S6114, P105-S6104, P105-S6102, P105-S9722, P105-S6062, P105-S6022, P105-S6084, P105-S6064, P105-S6034, P105-S6024, P105-S6158, P105-S6148, P105-S6207, P105-S6197, P105-S6187, P105-S6177, P105-S6167, P105-S6157, P105-S6147, P105-S6074, P105-S6054, P105-S9312, P105-S6014, P105-S6002, P105-S6004, P105-S6012 << hideThe printed instructions included with the Recovery and Applications/Drivers Media disc are correct for most computer models. For some models, however -- including those listed above -- booting from the Recovery disc requires pressing the F12 key, rather than the 'C' key. The instructions below are correct for these models.
CAUTION: The Recovery process reformats the computer's hard disk drive, which completely erases its contents -- including all applications, all documents, and all other data stored on the drive. Be sure to back up your documents and other data before following the instructions below.
Follow these steps to erase the current contents of the hard disk drive and to re-install all of the software that was installed on the computer when it was manufactured:
1. With the computer on, insert the first Recovery disc into the optical drive.
2. Shut down the computer (click the Start button, click Shut Down, select Shut Down, click OK).
3. Press the computer's power button to turn the computer on, and then immediately press and hold the F12 key. Release the F12 key when the menu of boot options appears.
4. Use the arrow keys to navigate to the CD/DVD option. Press the Enter key to select it.
The computer will restart, and will boot from the Recovery disc.
5. Follow the instructions on the screen to start the Recovery process.
CAUTION: Once the Recovery process has begun, do not interrupt it.
The computer's hard drive will be formatted, erasing its contents. All of the software that was installed on the computer when it was manufactured will then be re-installed.
6. Once the Recovery process is complete, remove the Recovery disc, and press any key to restart the computer.
- mc/wa
Jan 27, 2009 | Toshiba Satellite P105-S6207 Laptop
Wont start
Hello look!
I recommend a good anti-virus to you inserted the disc and you reinitiate asked to you if you want to initiate of the hard disk or the CD you say yes and cleaner all the virus, troyanos etc. after reboot the machine and ready! if with this no working you should be format the hard disc
Dec 29, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba L-25 Laptop
Got one here. Please remove the battery and power laptop on ac only. Please press the power button for 10 seconds until it turns on then immediately press on the F12 key. Release F12 upon seeing the boot selection menu. Please select the CD/DVD drive. Follow the rest of the instructions until the Recovery to the Out of the Box State. Hope this helps. Thank you.
Sep 21, 2008 | Toshiba Satellite L25-S119 Notebook
Factory settings
There's a couple of things you can do:
Press the F2 key to enter the BOIS setup and reset those defaults
and/or
Use the driver disc. It writes a complete image on the hard drive with all the drivers.
Apr 03, 2008 | Toshiba Satellite L25-S119 Notebook
Toshiba Satellite L25-S119 Notebook Logo
330 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
