Question about Refrigerators
Front too high
How do you level it
  • 11,896 Answers
The feet of the fridge can turn to adjust the height
Posted on Nov 17, 2009
How to Level Crossroads Cruiser
Which frame jack? The front landing gear or the stabilizer jacks at the rear of the coach? The principle in leveling is to utilize the tires and axles as the primary point of level. Make sure that you have your wheels/tires level from side to side first. Then using the landing gear at the front level from front to rear. The stabilizer jacks at the rear are not designed to support the total weight of the unit but rather to remove the bounce and sway. If the unit is raised too high with the stabilizer jacks the unit could fall to one side or the other damaging the jacks, the trailer or worse injuring someone.
May 26, 2014 | Crossroads 2011 Cruiser CTX CF25RBX
Level a refrigerator
Rinda,
Most refrigerators will have a leveling leg or wheel at each ot the front corners. What I usually do is lift the refrigerator up and set a block under the refrigerator and turn the legs or the screw for the wheels until they are at the point I want them and then remove the block. In your case, if you have leveling legs you will want to screw them into the refrigerator to lower the front. If you have wheels you will need a screwdriver or a nut driver and un-screw the bolt to lower the front. You may need to take the trim under the door off to access the bolts if you have wheels in the front. Hope this helps!
Jun 04, 2013 | Refrigerators
Ybr 125 swing arm bolt stuck
CAUTION:
Adjust the oil level in 5 mm (0.2 in) incre-
ments or decrements. Too low oil level
causes the front fork to produce a noise at
full rebound or the rider to feel some pres-
sure on his hands or body. Alternatively,
too high oil level will develop unexpectedly
early oil lock with the consequent shorter
front fork travel and deteriorated perfor-
mance an characteristics. Therefore, adjust
the front fork within the specified range.
Standard oil level:
90 mm (3.54 in)
Extent of adjustment:
80 ~ 120 mm (3.15 ~ 4.72 in)
From top of outer tube with
inner tube and damper rod fully
compressed without spring.
Apr 03, 2013 | Yamaha Ybr 125 Motorcycles
What angle should the dishwasher be high in front and how high
the dishwasher should be level.....with the door open check this with a level held against the vertical metal frame at the front side of the dishwasher (where the door seal is attached). Adjust the front leveling feet....one at each side until the front is vertical.....you will probably need a wrench to do this as the feet/bolts are usually quite tight. Be sure both feet are touching the floor when you are done.
Mar 24, 2013 | GE Nautilus 24" Built-in Dishwasher
The washer bounces really bad on the high spin cycle
Your washer may not be leveled properly. Use the adjustable legs to level your washer so it doesnt shake too much on high spin.
Oct 19, 2012 | Danby DWM5500W-1 Energy Star 1.69 Cu.Ft....
When I hook up the speakers in the back to the left and right side for the in and out, do I connect the front or rear speakers. do the speakers connect to the subwoofer first then to my receiver or the...
I was trying to find an owner's manual or picture of the rear panel of the sub, but had no luck. The subwoofer is a powered type - or "active" speaker. This means it has a built in amplifier. These active subs usually provide for one or both "low level" and "high level" inputs. Low level signals are usually carried by shielded coaxial cables and have RCA type plugs on the end. The low level is also called "line level". This is an un-amplified signal that might be heard on cheap earphones - but that's about it. It is similar to the output of a tape deck, DVD or phonograph. These signals require an amplifier to be heard. If you have a sub woofer output on your receiver or amplifier, you could run a patch cable between the low level input on the subwoofer and the subwoofer output of the amp or receiver. You receiver or amp may call this output "low frequency effects" or similar. The front and rear speakers would then connect directly to the receiver or amp's corresponding connections.
If you lack low level outputs on the amp or subwoofer, you'll need to run speaker wires from the amplifier or receiver's front left and right speaker output terminals to the subwoofer's high level input terminals. High level signals are speaker connections or amplified signals. These are typically connections that accept bare wire connections. The front speakers would then connect to the subwoofer's front left and right speaker output terminals. The rear speakers connect to the amplifier.
I hope this helps - and good luck!
Nov 24, 2010 | Cerwin Vega AVS-632 System
I have a Whirlpool refrigerator with an ice maker and when the icemaker is filling with water it leaks from the front of the tray into the ice storage bin.
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Feb 23, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Uneven cut
1-----------tire pressure? 14 front 10 rear
start with a level mower on a level surface
2------------deck level side to side?
3------------deck level front to back? (front can be 3/8 lower than back)
4-----------deck hangers bent or hung up?
5------------blades even when pointing at each other? no more than 1/8 high or low
6------------blades dull or upside down? turned up ends go towards deck
7---------------incorrect blades for mower?
8------------deck lifting mechanism should pick up deck evenly and drop evenly?
9-----------under the deck need cleaning because it is packed with grass?
Jun 15, 2009 | Garden
Washer machine is shaking terrible during the high speed spin
Alot of times with front loader machines they will shake at high speed even if the machine is level. The floor may not sturdy enough. You can put a piece of 3/4" plywood or something like that under you machine. I know putting plywood under your machine is not the best looking thing, but it should help the shaking. The product just needs to to sturdy.
May 28, 2009 | Frigidaire ATF6000ES Front Load Washer
Sony xplod amp xm-1652z high level input connection
First off, if you're using RCA preamp connections from the head unit to the amp, you don't need to put anything into the high level input connector. But if your head unit doesn't have RCA preamp outputs, then connect the front left to the white (+) and white/black stripped (-) wires and the front right to the grey (+) and grey/black stripped (-) wires. There is no need to connect the rear speaker outputs of the head unit to the high level input of the amp.
Apr 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Refrigerators Logo
202 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
