Question about GE WSXH208A Front Load Washer
The front load washing machine will not drain
My roommate washed a hand-hooked rug in the washing machine. Now the water will not drain.
    President:
  • 3,085 Answers
Look in the rear for a small door that holds the pump filter.
Drain the washer with the small tube 1st.
Posted on Nov 17, 2009
After washing bathroom rugs, my Frigidaire Affinity front loading washer would not drain the water out or refill with water
Often washing things like rugs and matts can cause real problems for the drain pipes on you machine. Have you tried clearing out the drain plug, located at the bottom of the front of the machine? If that doesn't work, the whole drain hose from the drum will be blocked.
thanks
www.recycledrum.com
Jan 12, 2013 | Frigidaire Affinity ATF7000E Front Load...
My washer is new, but it will not spin out the water. I was washing some rugs and it stopped and now it will not restart. We have cleaned the filter. Can you give me some ideas to fix the problem
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Samsung WF203ANW Front Load Washer
I washed a rug and the rubber backing came off in the machine and is now not draining?
heatman101
Oct 29, 2010 | Kenmore HE2 Plus Front Load Washer
I washed a rug and now it won't spin or drain
heatman101
Oct 08, 2010 | Frigidaire ATF6000ES Front Load Washer
Hi my washing machine is working but it sletting out alot of water,i think i put a rug in,and the rubber bit at the back all came off and has blocked something,i e filter or sumthing?? i sthere anything...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Sep 08, 2010 | Hotpoint Washing Machines
Stopped spinning from heavy rug
what is error, most likely plugged the pump
Apr 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
GE Profile washer will not drain. (DOES SPIN)
take the front off the washer take the two hoses off the pump youll probably find where its stopped up
Apr 24, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not empty water, wife washed backing came off
in the pump its at the bottom of the machine and where the drain hose hooks up. youll have to tilt the machine to get to it
Feb 25, 2009 | Frigidaire ATF6000ES Front Load Washer
GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Apr 16, 2008 | GE WBSR3140DW Top Load Washer
GE WSXH208A Front Load Washer Logo
73 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
