Question about RCA 27V550T 27" TV
RCA 27V550T 27" TV
27v550t rca tv asks for password ( never put in one). front panel blocked. called rca no help
  • gameknight Apr 16, 2008
    Same problem here. Happened spontaneously while using it. Procedure to reset password does not work (ie With tv off, hold button on remote and button on tv. Enter new password.) When I do this tv says incorrect password. Thinking V-chip may have gone bad.
  • danpro76 Feb 05, 2009
    I have same but solution not work and custumer have lock the front panel :((
Problem fixed. I unplugged the TV for 20+ seconds, then before plugging it back in, I shorted ac plug prongs together with a metal key to ensure complete discharge. Plugged TV back in and used procedure to reset password WITH ONE CHANGE TO THE PROCEDURE.
With TV turned OFF press and hold <CLEAR> button on the remote while pressing <VOLUME DOWN> button on the TV, hold until TV turns on. When the menu appears DO NOT RESET THE PARENTAL CONTROL CODE as the user guide instructs. When my menu appeared it was in the SETUP screen on the LANGUAGE setting. It was set to SPANISH, using the remote I navigated to ENGLISH. Then using the remote I navigated up to GO BACK. Then I navigated to EXIT and hit <OK> button on the remote. All was back to normal.
Posted on Apr 16, 2008
Has sound but no picture
no tube filaments in neck of the picture tube or no high voltage at all.
May 25, 2012 | RCA 27V550T 27" TV
menu > settings > security > change lock code > apply master code in place of lock code and press ok > enter new code what you want
Apr 07, 2010 | RCA 27V550T 27" TV
If it has either hdmi or or if it has red blue and green hook ups on the back of the tv you can go buy the component cables and hook it up that. If neither then sorry your outta luck
Mar 28, 2010 | RCA 27V550T 27" TV
Still can't get parental block to turn off on my RCA 27r410t. Have tried most of the steps found here on Fixya. Front panel is blocked also.
Unknown password-- ITC008 chassis with TV off press and hold volume down on the front of the tv and clear on the remote for 5 seconds
Feb 09, 2010 | RCA 27R410T 27" TV
Dead tv
you can also check cp025 & cp024. Now the problem with this power supply is if you find a problem with one of the following parts the have to be all replaced at the same time, because if one part goes it casuses stress on the other parts. Check the test the following parts tp020 dp033 tp023 (if installed) tp025 (if installed) tp022 (if installed) typically only have 2 of the last 3 installed in this tv. good luck.
Nov 10, 2006 | RCA 27V550T 27" TV
Restarting T.V
Sounds like the flyback transformer or the regulator is bad or could be both. There are no user serviceable parts inside of these sets so servicing should only be done once you understand the safty issues concerning the HI voltage and X ray radiation.. call in a pro to assist you. Good Luck
Jun 18, 2006 | RCA 27V550T 27" TV
RCA 27V550T 27" TV Logo
388 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
