Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd 52525 flashing green light cannot get it to stop, have already unplugged & reset, cleaned filter, unplugged and plugged pushed all buttons.... is there any other tricks?
  • Mitsubishi Master
  • 5,138 Answers
Replace 4 capacitors on DM board 1000uf use 25v
Posted on Nov 19, 2009
I have a WD-52525 set that the green light kept blinking after a power outage. The reset button never worked. I unplugged the set for 30 seconds and re-plugged it back in. The light began blinking between...
Bad digital/power module. Contact Mitsubishi, they may cover part of repair, I am serious. If not, have a an authorized servicer send module to Mitsubishi for rebuild program. The only economical solution.
Jan 18, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have a WD 62527. mfg Oct 2005, I have been dealing with this problem for two years. TV wont come on and green and yellow light flash, then just the yellow flashes all the time. I can push the reset...
which LED blinks yellow? that model has a filter in the back that you really want to keep clean. also make sure that the lamp door on the back is securely closed. the lamp door and filter are right next to each other.
Dec 23, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Our eletric went off today and when it came back on we had a flashing green light. There is no picture and we can not get it to power up. Please Help!
did you unplug the set and let it sit awile then plug it up. when you plug it up the light flash then you push the button then nothing happen. does it turn on with remote. also push and hold menu button on front for 10 seconds. Try these things out first
Dec 10, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I unplugged the tv to use the outlet for something else. When I plugged the tv back in and turned it on---I get the timer light (green) flashing. I have waited and waited for it to stop and it doesn't....
Defective capacitors on the DM leaving it plugged in the caps still work sice they'r e charged, But unpluggung allows them to discharge then they wont charge up again since they're defective so you get the blinking light. You can get the V26 DM repair kit from www.tvrepairworld.com which has the replacement capacitors and the CD with repair instructions.
Dec 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Fan stopped red light blinking
1. Unplug power to set, Remove filter, clean filter, replace filter.
2. Hold in reset button on front of set with set powered off for about two minutes.
3. Plug in the set, green light flashes for about a minute and goes off. Turn set back on.
4. If you think you need to buy a new power supply go to Mouserelectronics.com. Roger R. R.
Mar 01, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green light and clicking noise AFTER bulb replacement
do this. press and hold device and menu button on set for 5 seconds. this will retrieve a 2 digit error code .. the led will flash the first digit and pause the flash second digit. This unit is known to have capacitor problems on the power board. getting to these capacitors involves taking alot apart. let me know error codes and we can continue troubleshooting
Jan 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
177 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
