Question about Motorola Cell Phones
I cant her when someone is speaking to me unless i turn on the speaker or the walkie talkie but, the other party can her me,my earpiece is is not working?
  • 5,081 Answers
Its not speaker its problem with the software in the phone.
I had this problem on my phone and i did a software reset giving it to a repair shop and it was a easy and cheap fix .
He re loaded the software and i was all ready to keep talking.
Posted on Nov 17, 2009
I have slyvania walkie talkies model no.fbs201 working but not sure how to turn off and on..
I could not find your model on the internet. Sylvania was never a walkie talkie manufacturer, so they were made by someone else. The ones I found on eBay had an off/on switch tied to the up down keys. Try pressing and HOLD for about 3 seconds the left side bottom button, then release. If that did not power it on, try the other buttons but be certain to HOLD for about 3 seconds since the button is dual purpose.
Oct 31, 2016 | Walkie Talkies Radio Communications
Use a audiovox walkie talkie
What is your question about using the walkie talkie? These are standard FRS low power walkie talkies. You need to set both to the same channel. Turn both on. Push the transmit button and speak into the microphone which is on the face of the radio. You should hear the voice in the other walkie talkie.
Note; all of these FRS talkies have substantially less range than advertised. They should provide reliable service within about 1/4 mile line of sight, no more. In an urban environment with lots of buildings you will get less.
Oct 14, 2014 | Radio Communications
Sx700 continuous transmitt
PTT short circuit, remove the short
Jan 30, 2014 | Motorola Walkie Talkie 2-Way Radio
How to find someone using a wallis talkie
Program your existing walkie talkie to a common frequency with no PL code turned on and listen for activity. If you are using a TalkAbout or other FRS radio you should hear activity on one or more channels if you are in a city.
Best regards.
Mar 16, 2013 | Motorola Walkie Talkie 2-Way Radio
Spy gear walkie talkie
Spy Gear walkie talkie????
You've not given me any other info, so how can I help you?
Please reply with the following info:
1. Make & Model of your radio.
2. Your question in regard to the radio, i.e,. THE PROBLEM WITH IT.
Unless I receive as much info regarding your radio, I am unable to give you an answer.
Cheers,
Peter
Mar 05, 2013 | Wild Planet Spy Gear Long Range Walkie...
Only one unit of my Uniden walkie talkie model no 1038-2 works
Check programming. Channel and selective call must be the same on both radios. Check "mic" opening hole on the front case of the radio. The slightest bit of debris blocking this tiny hole can reduce transmitted audio to zero.
Jul 26, 2017 | Uniden GMR1038-2 (7 Channels) 2-Way Radio
T5900 Walkie Talkie Issue
Hello Bo Duke,
If one radio won't walk to the other my guess if that you have the Privacy Code function set up incorrectly.
The privacy code function mutes the radio unless it receives a signal from another radio transmitting the same privacy code. If Privacy Codes are turned on for Radio A but not turned on for Radio B then you will be able to transmit from Radio A to Radio B but not from Radio B to Radio A. If Privacy Codes are turned on for both radios but each unit is set to a different code then neither radio will be able to talk to the other.
Make sure that the radios are both set to the same privacy code or that the privacy code function is turned off on both radios. You can find more information on how this function is set in the radio's Owner's Manual.
Hope this helps!
Ken
"Go Ahead. Use Us."
Jul 02, 2008 | Motorola Walkie Talkie 2-Way Radio
Motorola T5700 Talkabout Series
It would seem that this is a problem with the contact/switch of your Motorola T5700. When a headset, ear piece or external speaker is plugged in, an internal switch transfers the connection from the speaker to the external. This is better illustrated in the image below.
Initially, you can try an electronic contact cleaner. If that doesn't work, you may have to open the unit and manually scrape off any corrosion from the contacts/terminals or slightly bent it to improve contact.
Hope this be of some help/idea. Pls post back how things turn up or should you need addition al information.
Good luck and kind regards.
Nov 02, 2007 | Motorola Walkie Talkie 2-Way Radio
Cell Phones Logo
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
