Question about Dell A920 InkJet Printer
Print spoole first when i try to print something itsays "before you can perform print related tasks such as page setup or printing a document,you need to install a printer. then i try to install the printer and it says " operation could not be completed print spooler is not running. & i tried going to run>then type service.msc>then look for print spooler & press where it says "Start the service" But then it says:Could not start the print spooler service on local computer. Error 1068: The dependecy service or group failed to start.
  • Anonymous Jan 15, 2008
    Same problem, different printers but sorry no resolution yet.
  • 58 Answers
Has this been resolved?
Posted on Feb 14, 2008
How do I clear the memory
I would think that the document is not on the printer, it's in the printer spool. Open the printer properties and clear the queue.
Mar 13, 2015 | Office Equipment & Supplies
Prints PDFs VERY, VERY Slowly...Something's Wrong...
See if print spooling is turned on. If using windows check the control panel or use task manager to see if spooling is active and running
Jul 11, 2012 | Lexmark X204N All-In-One Laser Printer
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
Aug 17, 2009 | Canon PIXMA MP610 InkJet Printer
Before you can perform print related tasks such as page setup or printing a document you need to instal a printer
hi... did you install your printer? if so, then you have to uninstall that.. go to menu/all programs/control panel/add or remove programs/... then reinstall that.. and pls you have to enable the twain driver of your printer...thank you very much..
Jul 10, 2009 | HP LaserJet 1500L Printer
Printer only prints one page of multiple page document
hi..
You may try to change the spool data format:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
("Start," "Control Panel," "Hardware and Sound" and "Printers" for Vista...)
2. Then, right click on the Lexmark printer icon and left click "Properties."
3. Either on the "Advanced" tab or the "General" tab for some models, there is a "Print Processor" button, left click it.
4. This is the spool format setting. Under "Print processor" it should be set to "Lexmark *** series print processor." Next, under "Default datatype," select "NT EMF 1.008."
5. Click "OK" and exit back out to your desktop.
6. Try printing again.
Apr 24, 2009 | Lexmark P4350 All-In-One InkJet Printer
Printer
spooling, is where the information being sent to the printer is being checked/converted for the printer driver , prior to being printed
Jan 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
PRiNt SP00lER
1. Go to Start > Run and type in services.msc then press Enter. 2. In the window that opens find "Print Spooler" on the right 3. Right-click "Print Spooler" and select "Properties". 4. Click on the "Recovery" tab and change all 3 drop-down boxes to "Restart The Service". 5. Make sure the 2 text boxes underneath say "1" in them. 6. Click Ok until you are back at the Services window, close it and you're good to go. 7. Go back into the properties of the "Print Spooler" tab and be sure to click Start to restart the Print Spooler service and it will restart the service immediately.
Jan 08, 2008 | Dell A960 All-In-One InkJet Printer
PRiNt SP00lER
Try this FixYa for Error 1068.
Let me know how it goes.
Jan 08, 2008 | Dell A920 InkJet Printer
Print spooler
HI ,
This is JISHKUMAR, U need to click on dependencies tab.this u will get it when u double click on print spooler.just look which are the services under dependencies..whatever services you will find just go to that services and start them and then start print spooler service. this will 101% solve your problem
Dell A920 InkJet Printer Logo
113 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
