Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
The ice will not come out of the icemaker when the lever on the door is pushed. Can I troubleshoot this problem?
  • 4,059 Answers
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
Posted on Nov 17, 2009
Water flows into ice maker when water lever is pushed
Be sure that you have the water inlet valve wired correctly.
Nov 26, 2012 | Refrigerators
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Model 501-78353 dispensing water but icemaker has not worked since it made one very large batch of ice and the lever rose - I guess to stop the icemaker
yes the lever needs tp be push lightly down and then the ice maker will be in on position again. then the ice maker will call for water then it should start making ice in a few hours.
Feb 13, 2011 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My ice maker makes ice but will not dispense it
When you push the lever to dispense ice, can you hear the motor running? If not, that motor might be dead and not turning the auger, which would be your problem.
If you can hear the motor and auger turning, the chute or the opening in the ice maker might be clogged up with ice. Clean the entrance to the ice maker and the chute in the freezer door and that should fix your problem.
Dec 13, 2010 | GE Monogram ZDI15C Automatic Icemaker
My icemaker won't switch back to cubed ice. all i keep getting is crushed ice. HELP
If you select cube and hold open the door and push in on the light switch and have someone push the lever for ice you should hear a loud click this is from the selector switch in the back that engages a long brass colored rod under the ice maker if you hear this loud click you probably have some crushed ice in the crusher keeping it from switching back open the door and push in on the light switch and have someone push for cube ice it will kick ice out the bottom so dont be alarmed. (sometimes you have to do this a couple times) good luck
Aug 16, 2010 | GE Adora (DSF25KGTBG) Side by Side...
After 2yrs of not using the icemaker, moved
Good day,
Pour water from small paper cup until it near fills the well of the ice maker. With the lever down, close freezer door and wait 2 to 3 hours. If it dumps then the ice maker should be good, if not, replace ice maker.
If dumps O.K. then the dual water valve is bad, and needs replaced.
You should check the fill tube that runs from the back of the machine to see if it is blocked with ice. (requires removing ice maker) but even so, if it is iced, you'll need to clear, but the water valve in the back rear of the machine is leaking and still needs replaced.
Thanks for using FixYa
Dec 20, 2009 | Refrigerators
Ice maker leaks water into Ice bend. When it cycles I can watch it drip water from the ice maker.
not familuar with the brand but sounds like one of 2 issues
if it is overfilling making ice cubes larger than normal, adjust the ice maker fill time if it is possible
icemaker fills and cuts off but water valve seeps water after the fill causing the water overfill
one of the 2
Jun 23, 2008 | U-Line Icemaker
Ice maker constantly runs
You do not have the actuator postioned correctly on the switch inside the door. The lever has to press up against the switch when you push it. Re-postion the lever.
Apr 11, 2008 | Frigidaire PLRS267ZAB Side by Side...
Icemaker does not work
check the water hose. water supply to ice maker
Sep 11, 2007 | Roper RS22AQXKQ Side by Side Refrigerator
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
104 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
