Question about LG enV VX9900 Cellular Phone
Cant getmy jabra bt8040 to connect with my lg shine
What if i can't find my model phone for instruction to connect to?
Hi
Paring the JABRA head set to Mobile phone
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT2070.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank You
Aug 31, 2010 | British Telecom Jabra BT8040 Wireless...
Can not find instructions to connect jabra bt8040 to my cell phone,,,,now that hands free is law as of today!
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Oct 26, 2009 | Jabra BT8040 Bluetooth Headset
Can't get new Jabra BT8040 to connect to LG Env3
I have the env Touch and the Jabra Halo. Initially, I had a problem pairing the two, then I realized that I was not following the directions properly. The manual shows two sections for pairing ("first time pairing" and "later pairing"). I was following the instructions for the former when I should have been following the latter. I also failed to notice that the BT indicator was flashing blue and not solid blue, as it needs to be, for pairing mode. So, if you haven't already done so, follow the instructions for "later pairing" here. Make sure that you see the SOLID blue light on the BT indicator on the headset when you try to pair.
Jul 17, 2009 | LG enV VX9900 Cellular Phone
Jabra bt8040 is not pairing with iPhone 3gs
No problem. When Jabra is off, press and hold till green light turns blue. On the iPhone: settings, general, bluetooth; switch to on. It will search, then it will list the Jabra BT8040, not paired. Highlight the "not paired" line, and it will start to pair; a few seconds later, it will say "connected".
Jul 09, 2009 | Apple Cell Phones
Soft ear pad for jabra bt8040
http://www.msgdigital.com/productdetail.asp?productid=46551
Feb 18, 2009 | Jabra Bluetooth Headset with Adjustable...
Jabra BT8040 is not pairing with iPhone 3G
Make sure the headset is off. iPhone--Settings--Bluetooth---On---Press and hold the answer/end button for approx 5 secs until lite turns sold blue. It works
Nov 12, 2008 | Cell Phones
Lg SHINE CU720
I have a LG VX8300 cell phone and it works fine with my Jabra BT8010. It also connects fine to my Dell XPS m1210 and my Motorola cel l as well. Hope this helps someone.
Feb 18, 2008 | Jabra BT8010 Wireless Headset
LG enV VX9900 Cellular Phone Logo
59 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
