Question about GE Refrigerators
I need an ice bucket with auger for a GE Profile, part #203C4025P009
  • Leroy Elliott
    Leroy Elliott Nov 17, 2009
    I've tried that, you have to buy a whole new ice maker.
  • 2,237 Answers
Try www.partselect.com. you'll need the model #.
Posted on Dec 21, 2009
    President:
  • 3,085 Answers
Found one on eBay.
Ice dispenser
THere is a plastic "hub" at the back of the bucket which attaches to the auger. THE "hub" catches a "fork" like device at back of ice maker which turns. The "fork" turns and in turn is supposed to turn the auger. That plastic hub could be torn up, broken, jammed, or otherwise not working correctly. That is what is wrong with mine.
Jul 19, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker problem
something has to give when it too hard to turn. if ice cubes are ice to each other it could cause this . sometimes this is caused by water leaking from ice maker into the bucket . look for a bad water valve or a ice maker that is not lever or has bad tray . . ****
Jan 19, 2010 | Refrigerators
Model # tpx24prdabb ge profile side by side. the auger dosent turn at all. i took the light bulb out, no luck. it clicks but no auger movement.
Good day,
Three possibilities.
1. The auger motor is frozen up and cannot turn. Needs replaced, but sometimes it can be removed and air dried for a few days by simply leaving it on the counter then, rotate by hand to test it can rotate, reinstall and test.
2. Control switch in door has failed.
3. Overlooked many times but there is feature that prevents the auger from running when the door is open. It is a switch which is part of or next to the freezer light switch.
P.S. remove the ice bucket, dump or remove the ice, clean,
and make sure the auger turns freely.
Nov 04, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker makes plenty of ice, no problem with the water either. My problem is that the auger will not turn to dispense the ice out of the bin. The motor kicks on when you push in the buttom, however it...
Pull the ice bucket out, then hold in on the door light switches and while you push a glass into the button for ice (may require two people). Ice dispenser and auger will only work, when you push for ice, when the freezer door is closed, so by holding the light switch(s) in the off position with door open you can simulate door being closed. If you can push the button and see the auger drive turn (with ice bucket out) then check to see if you have some ice stuck between the blades on the bucket, if the auger motor doesn't turn, it may be "ice frozen". Common problem. Remove motor, let sit on counter for about three hours and then reinstall, if it then works then check for water dripping from the fill tube, where the water comes into freezer for the ice maker, and see if it is dripping onto auger motor.
If you put auger motor back in and it still won't turn then more and likely you need an auger motor.
Let me know.
Oct 09, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ice maker drive mechanism won't turn
Remove ice bucket and rinse throughly. Hold down door switch an press for ice you should see the drive in the back for the auger turninig if not youll need to find out uif auger motor is getting electricity and/or is operable.
Mar 15, 2009 | GE Profile PSS26NGS Side by Side...
GE GSS25LGM Ice maker not dispensing ice
You have one of three things wrong. The auger motor is frozen up, the ice bucket is broken or you need to dump out any ice, run warm water through the entire ice bucket, dry it out and try again with fresh cubes. My guess is the auger motor is frozen. You can buy a vinyl boot that covers the auger motor to prevent moisture buildup and freezing from GE Parts at 1-800-626-2002
Nov 21, 2008 | GE GSS25LGM Side by Side Refrigerator
Ice Dispenser not working on PSS26SGPA Stainless Side by Side
This is a common problem with this GE and "lookalike" models. The dispensers first break the front plastic drum that holds to the auger and eventually cracks the rear circular sleeve as well. Pieces from the drum usually fall off and are even dispensed with ice ... eventually the drum is damaged enough that the auger no longer operates. The motors on these units, however, continue to operate.
You can receive the replacement parts needed to make the ice maker auger operate again by visiting the GE parts website. A usual repair will run $40-60. Unfortunately, the design of the replacement drum has not changed, so be prepared for this to happen again.
Best of Luck.
Apr 24, 2007 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
255 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
