Question about Mintek MDP-1760 Portable DVD Player
Mintek DVD player
When put a disk in it spins (says loading) but nothing else happens.
Maybe there is a proble in the turntable motor, try this:
1.- disconnect the motor.
2.- put some drops of alchool in the motor
3.-with an external power suply make it wok in both directions
reconnect and check, what happen.
Posted on Jan 10, 2008
When I load a dvd into the player, after a while it says "no disc" and nothing plays.
Do the "bad" disks work on some other DVD player?
Or, do the "bad" disks work on some computer with a DVD drive?
Dirty disks with lots of greasy fingerprints?
Feb 16, 2014 | Sanyo Televison & Video
Mintek portable dvd player
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you. I hope this information helps you with your problem.
Apr 08, 2009 | Mintek MDP-1815 Portable DVD Player
Loading but nothing happens
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.I hope this information helps your problem.
Apr 07, 2009 | Mintek MDP-1810 Portable DVD Player
Toshiba sd-4990 dvd player will not load a disk
Your toshiba is not spinning that's why it keeps on saying loading. Unplug the dvd Open the device,once open plugin the dvd and put the dvd cleaner in the player. take your finger on the top where the dvd disk is and spin the disk. What happening is that you are cleaning the len. keep spinning until it spin on its own.Put the toshiba top back on and clean again. It should clean on it's on. Now you can play your dvd. Clean your dvd on a regular basic.
Mar 12, 2009 | Televison & Video
Screen comes on, disk turns, loading starts, and doesnt stop
Feb 01, 2009 | Mintek MDP-1770 Portable DVD Player
My mintek dvd player says no disk
Dec 07, 2008 | Mintek MDP-1815 Portable DVD Player
It won't spin
oh no!!! that's bad dude!! have it checked to a liscensed technician since the player is malfunctioned. This is one of the most common problems with players especially if it played for long hours..
Feb 05, 2008 | Mintek MDP-1030 Portable DVD Player
Loading
Does this happen with 1 dvd, or multiple?
Jan 27, 2008 | Mintek DVD-1810 Portable DVD Player \
DVD does not play just spins and keeps showing loading.
Check to see if the disk is dirty, has fingerprints or is scratched. This has happened to me in the past and if dirty, cleaning it will correct the problem.
Jan 02, 2008 | Mintek DTV-373-D 37 in. LCD HDTV
Nothing happens
MAY BE THERES A PROBLEM WITH YOUR POWER SUPLLY TRY TO GET A NEW POWER SUPPLY, IF THERES NOTHING HAPPEN MAY BE YOUR BOARD HAS THE DEFECT
May 03, 2007 | Mintek MDP-1760 Portable DVD Player
Mintek MDP-1760 Portable DVD Player Logo
159 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
