Question about Maytag Performa PAV2200
When the load gets unbalanced the machine keeps running. Is this normal or should the machine stop?
    Brigadier General:
  • 4,090 Answers
It has to be stopped manually and then you redistribute the load. It does slow down on some models to try and rebalance itself by water swirl, but is not really succesful. So back to manual stop and redistribute
Please rate my help++++Thanks for using fixya
Posted on Nov 17, 2009
Why does it always become unbalanced in spin cycle?
how confident are you to get inside it? Check the balance springs and shock absorbers.
Normally it is two simple things.
First the machine must be level front to back and left to right. Also all 4 feet must be in equal contact with the floor.
Make sure you load the washer evenly with clothes. Mix large and small items so when the spin starts the clothes even out. Never wash just one large item that is very absorbent, like one bathrobe or one blanket..
Dec 26, 2015 | Washing Machines
Whirlpool Cabrio 580 is unbalanced and will not complete a wash sequence
USEUALY IT IS MOST LIKELY THAT THE UNIVERSAL JOINT UNDER THE WASH PLAT AT THE BOTTOM OF THE TUB HAS GONE OUT .SHOULD BE REPLACED . THAT SAID PROBLEY WISE TO GET A TECH TO REPLACE IT . ON THESE YOU HAVE TO HAVE A SERVICEMAN TO REMOVE AND REPLACE THEM ..
Apr 25, 2017 | Whirlpool Washing Machines
Wixe167 just stopped running while spinning on last cycle
It stops spinning because the load is unbalanced. It will cycle over and over until the load is even then it will kick into a faster spin. Unbalanced loads could be due to too many items in the washer of a stabilizer problem in the hardware of the machine,
Oct 26, 2013 | Indesit Washing Machines
Whirlpool cabrio W10106480A keeps giving Unbalanced Load message and tub bumps the sides very hard and loudly
follow this step and fix it. God bless you
Washing machines are complex and have many functional components. It's always best to stop an unbalanced load, rearrange it, and re-start the washer.
Oct 01, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
LG washing machine direct drive when i put it on it washes and goes down to 9 mins then stops, sometimes an error code comes up UE? CAN U HELP PLEASE
It means Unbalanced Error, it means the machine cant balance the load during the spin cycle, normally happens if there is too little a load i.e 1 or 2 things or overloaded. It is designed to protect the bearings. If it happens with a normal load try stopping it and re-arranging the load by hand and putting it on a spin only cycle. Hope this helps.
Feb 28, 2011 | Washing Machines
Unbalanced load- spin cycle stopped . cannot get machine to start
Hi just read your posting .Do you still require help?If so reply back and I am sure I can help you.
Jul 12, 2010 | Fisher and Paykel IWL12 Top Load Washer
My washer just stopped without doing the final step (spinning). Now all the controls are flashing and it looks that I can't stop them.
if the load was large and unbalanced the machine went into safe mode to stop it spinning so it will probably be ok on a normal wash
Dec 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My machine will not run the spin cycles, and makes a very loud noise during the spin cycles, sounds like a bad motor or bearing?
I'm not a repair professional. I am just a 78 year man who has done his own washer repair for about 50 years. You might have a bad lid switch that keeps the washer from spinning. You might have an unbalanced load in the machine which makes the noise. The unbalanced load might also be the cause of not spinning.
Nov 23, 2009 | Hotpoint VBXR1090B Top Load Washer
During spin cycle it becomes unbalanced and it beeps and stops
It sounds like the sensing arm of the out of balance switch assembly is wrongly set. Get the guy back to do the job properly at no charge!
Oct 19, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Two speed auto washer - found water all over floor - no leaks on any hoses or drain. Wife said last load was unbalanced and machine was rocking around bad. Tub seems very wobbly to me when I move it...
having a very unbalanced load can cause the water to go over . yes the tubs are supposed to be able to move around some.run a load with no clothes in it if it leaks then you may have a more serious problem
Jul 26, 2009 | Whirlpool LSB6200KQ Top Load Washer
Washing Machines Logo
118 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
