Question about Sony KP-61S75 TV
No remote control works anymore
Is as if internal battery died but can't find one in the tv.
    Scholar:
  • 86 Answers
Good evening friend. you seem to be having problems in your standby circuits if no remote works on the tv, but you can operate it manually. the standby circuits always stay on that is how you are able to power up the set. go to your remote infrared circuits when this problem exists find the standby transformer and the other parts of this circuit. check for opened or shorted components. find the transformer fuse and bridge rectifiers. somtimes these can be on a seperate board. you might even find a transistor and zener diode regulation circuit in the output voltage source. be very mindful of that standby crcuit. thank you and please rate this solution
Posted on Nov 17, 2009
My samsung 3D led multisystem smart TV remote control does not work anymore
It needs to be Re-Paired to the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Please rate if Helpful.
Good Luck !!
  1. TV off
Within 3 feet of TV
PAIRING
and RESET buttons:
Apr 15, 2014 | Samsung TV Remote Control
Remote control sometimes is working, most of the time is not working, so I have to turn it on and off manually
Tries check the tv remote battery compartment for moisture and rust on the remote battery like + - connections inside of the battery compartment?Yes?Take somethings sharp or a knife scrap all the rust out.Take a rag spray some WD40 and clean the + - battery compartment connections.Change another set of a new battery.If after this the tv remote still have the same problems,than the remote itself rubbers inner layer of the rubbers knobs probally warn out and not anymore make correctly contact to the tv remote PCB board anymore or the CPU chip itself it is slowly dying and shorting out of the tv remote CPU,remote devices are heavy dependent on it CPU chips.Or try website like Remotes.com to buy the tv original remote or very closed clone compatible one.
Sep 05, 2011 | Olevia LT32HVE 32 in. LCD Television
Have a protron pltc-26 and the remote qiut working put in fresh batteries but will not turn on tv
The remote control is dead or the remote CPU chip that control all functions is dying and only some of functions buttons will work,some wouldn't anymore or the rubber insulater between the rubber buttons and the remote circuitry board are worn out and make no more contact.Can u take the remote aparts?Yes.Check all the rubber butttons insulater see if they're still good.Tries clean the remote PC circutries board with some rubbing alchahol also the battery - + connections too.Wait like about 20 mins for the rubbing alchahol to completely dries.Putting it back together again an putting in new batteries,the remote control might work again.If not have same result.Try website like Remotes.com to buy an original or very close compatible remote for a replacement.
Mar 23, 2011 | Protron PLTV-26 26 in. HD-Ready LCD...
Hitachi CLU-5713TSI remote control won't work anymore. Acts like it needs to be programmed again. Press tv button, light comes on then fav channels and snow comes on tv. Can't access anything
Take off the battery, open the back of your remote, lift the circuit board clean the green painted part of the circuit board with cotton balls slightly damp in rubbing alcohol, as well as the black thingy at the back of your remote pad, let it dry put it back together, change with a new battery and see if it works.
Jun 12, 2010 | Hitachi CLU-5713TSI Remote Control
Dropped the remote and batteries fell out. Put
Check ur universal remote manual for ur tv codes.Re enter ur tv model universal codes.Ur remote should work again.Try website like 1-800-Remotes factory original.Buy an exact remote to ur tv original remote.Never care for codes agian,because u have the original remote.
May 06, 2010 | Philips Universal PH301S Remote Control
Remote not working anymore for my LG 42PQ20. Ive tried changing
call LG if you think the TV is not accepting the signal from the remote the TV may have a fault in it. If you have any universal remotes try programing them to control the TV if they work but the other does not it is remote.
Mar 15, 2010 | LG 42PQ30 42 in. Plasma TV
Ht3915 remote died, need one, help, ty
Check in the remote to see if the batteries are good. Check the battery contacts to see that they are clean and there is no corrosion.
If this still does not work, try another known working remote for your model of set. If this still does not work, then the fault can be the remote sensor inside of the TV set, or a failure in the processing area for the remote commands. An internal remote problem with the TV will be involved with troubleshooting.
Jerry G.
May 04, 2008 | Audio Players & Recorders
Remote wont work
for some reason unknown, the laser or infrared diode has died
May 20, 2007 | RCA 257003 Remote Control
Sony KP-61S75 TV Logo
77 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
