Question about Mtd Garden
Tec 3.5 horse - 2 cycle - pull start - mtd snowblower - has spark and fuel - won't fire or start -
    Scholar:
  • 110 Answers
Give it a shot of starting fluid, if it fires, it has a fuel problem, if it does not fire then you have a broken flywheel key.You will have spark with a broken or partially broken flywheel key, but your timing will be off and it will not run. good luck
Posted on Nov 17, 2009
Does 4-stroke and 4-cycle mean the same thing?
yes ... intake, compression, power, exhaust .... vs 2 cycle which mixes them down to two.
Mar 30, 2015 | MTD PRODUCTS INC Craftsman 21" 179cc*...
Have no spark to plugs
Those sensors have no effect on spark. Did you replace the plug, if not remove it hold it against the engine, have someone pull cord, watch for spark. If you have spark then you have a fuel problem. If no spark then after replacing plug, then remove stop wire from magneto side. Pull cord an watch for spark. If no spark then remove housing an flywheel, measure gap between mag an flywheel. Check to make sure magnets are still on flywheel. Call some shop or check a service manual on gap setting. If no spark still you will need to replace the magneto. This is rare an its is more likely a plug that needs replacing. Toro snowblowers are nice machines, this is not a hard fix. Really to tackle this is starting with the plug.
Mar 16, 2014 | Toro Snowblower 826 Oxe 38624w With 3 Year...
MTD Snow Blower will NOT start up!
fuel float stuck --- need carburator repair -- to check it has spark then pull spark plug --- if wet blow off spark plug and check spark on plug then squirt a small fuel out of oil can into plug hole and put plug back in -- if engine fires on first pull carburator needs fixing -- check by squirting fuel in carburator with oil can and see if you can keep it running
Feb 23, 2014 | Garden
Torn down Yard Man wont start
Fuel related if you can get it to fire with starting fluid.
May 12, 2013 | Mtd Garden
Fuel pump cycling long time bike won't fire,has good spark.
Hi, Anonymous and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
What to do When Your Motorcycle Won Start
1098 won start
Ducati 907 906 Paso Workshop Service Repair Manual 1988 1993 Searchable...
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Mar 14, 2013 | Ducati Motorcycles
MTD Yard Machine 675 series 190cc Always started now won't, does not turn over. Can pull it to start but does not start. What can we do to fix it. One year old, never had problem before. Machine...
Based on you question, this could be anything (like going to your Dr. and telling him "I'm sick"). That being said, if it just sat with gas in it, then it's likely a fuel problem (ie; plugged carburetor). These machines do not like the new Ethanol Gas and they cannot be left to sit or they'll gum up on you. An engine needs three things in order to start and run. 1. Spark 2. Fuel 3. Compression. First check your spark; if there is no spark, it'll never start. If there is spark, then I recommend a good carb cleaning. Better left to a professional if you're not familiar with this procedure. I hope this gets you started in the right direction. Best of luck to you. (You can find "how-to" videos on all these procedures by searching on YouTube)
James
Oct 15, 2011 | Mtd 22" Yard Machine Push Mower
My yardmachine snowblower won't stay running. It starts if I pump the primer. Fires up than dies. The fuel line isn't clogged, but once it starts it seems like the throttle cable has no tension (floats...
empty the fuel bowl & tank. start out with fresh fuel for one. then get a new spark plug if it still dont start. as far as the cable thats another deal completely but it shouldnt cause it to stall out. but if it ran last year it will this year too. always run it empty for summer storage. its your personal choice if you use a summer storage lubricant.
Feb 09, 2010 | Mtd 22" Yard Machine Push Mower
MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
Jan 26, 2010 | Mtd Products Yard Machines 158CC Tiller
Snowblower: fire from muffler
Try changing the spark plug. You may be having some misfiring going on here. Is your fuel to oil mixture right?
Jan 28, 2009 | Craftsman 4 Cycle Blower/Vac
My MTD 524 5 horse snowblower will start and run for about 3 to 5 minitues and then stall. Will restart after priming a few times and then die when blades are engaged. I installed a new spark plug and same...
This sounds like a fuel issue. Could be bad gas, water in the gas, improper gas/ oil mixture (if 2 cycle), wrong or incorrect level of crankcase oil (4 cycle) or a partially plugged fuel filter.
Oct 24, 2017 | Office Equipment & Supplies
Garden Logo
110 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
