Question about Ricoh Aficio 250 Copier
Ricoh Aficio 250
When connected to a computer with windows 2000, I can not get it to print from the computer to copier and using LPT-1. It was working and now it shows error and when retry it still will not copy from computer, but it does make copies when on the machine.
Smithins1@aol.com
    President:
  • 4,402 Answers
Unplug and them plug back in
Posted on Jan 10, 2008
RICOH Aficio 3045 Necessary HELP!!! Necessary
If you go into "user tools" is there a printer and scanner option there? If not the MFD does not have the print option.... If it does you need to program the IP address sub net and gateway. -Carl
Sep 18, 2016 | Ricoh Aficio Office Equipment & Supplies
RICOH Aficio 3045 HELP!!! Necessary
If you have used various computers with different OS's and you still cannot get any to recognize the printer, then it would appear that the printer electronics are fubar.
U might check with Ricoh but ......................
Sep 17, 2016 | Ricoh Aficio Office Equipment & Supplies
I'haven't driver usb for Aficio mp161 windows XP 32 bit,thak you
Hello!
The driver in not diferent for TCP/IP or USB. The driver is the same.
You just need to configure the LPT port and connect your machine to that port (usb port)
If you do not have the drivers you can download it for free from www.ricoh-support.com.
See you
Aug 05, 2011 | Ricoh Aficio MP 161 Black and White Copier
I have my Ricoh Aficio MP 2000 connected to my computer via USB but my computer does not recognize the scanner. I can however print from my computer to the Ricoh. I tried installing the TWAIN driver,...
I have the same problem. I use the USB, my client is far far away from me, and is better for me install the Ricoh using the USB. But the scanner don't work.
Maybe the only way is using a ethernet cable, but i dont want to drive so far... :(
Oct 01, 2010 | Ricoh Aficio 1018 Printer
HOW to configure ricoh aficio 2032 on nework and install it on more than 1 pc. this printer is connected via ethernet cable to dlink switch, where my other pcs are conected. but i cant connect it on any...
You install driver for the Aficio 2032 on all computers where you want to be printed from it.
Then you will go to Printer driver properties and then need to be created port TCP/IP and write the address from the printer it's same as connecting a computer on network
Jun 30, 2009 | Ricoh Aficio SP C210 Laser Printer
Use as a scanner .... How to ?
you must first connect scanner interface drive board
Jan 22, 2009 | Ricoh Aficio 1085 Laser Printer
Ricoh nrg mp 1600 Aficio copier/scanner/printer
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Nov 07, 2008 | Ricoh Aficio 250 Copier
Printing from PC to Copier with USB cable
The drivers might have a tough time recognizing a 250 as a usb device on your computer. There wasn't a USB interface created as an option on your copier. Does your copier have a network adaptor on it?
One idea that will work on your copier is a parallel print server either wired or wireless. I've done this for a few of my 220/250 customers.
Nov 05, 2008 | Ricoh Aficio 250 Copier
HO TO FIND THE RIGHT DRIVER FOR RICOH AFICIO 250 COPIER
Goto ricoh-usa.com and select the correct drivers from the model number for your copier.
Use the PCL drivers only.
Oct 19, 2008 | Ricoh Aficio 250 Copier
Printing from PC
use parrallel cable. if there is ethernet port u can use a cross lan cable also.
Sep 02, 2007 | Ricoh Aficio 250 Copier
Ricoh Aficio 250 Copier Logo
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
