Question about GE DCSR483EA Electric Dryer
Ge select electric dryer
My sister has a GE Select electric dryer less than 3 yrs old. When she has it on regular heat the dryer will begin making a loud screeching sound. The back of the dryer gets really hot, although the exhaust tube stays fairly cool. If she puts the selector on a lower setting the noise stops but the clothes don't get dry. I pulled the exhaust tube off and felt as far as i could inside and felt no blockages. I can't seem to figure out which side comes off for access. It's a front loader dryer. Please advise.
It may be clogged on the inside of the machine not just the exhust tube.
Posted on Jan 10, 2008
6ya staff
SOURCE:
GE dryer dwsr463eg7ww timer isn't working and doesnt heat up
The heating element assembly warms the air before the air enters the dryer drum. If the dryer won't stop, it may be because the heating element assembly isn't working - which greatly increases the drying time. Check the heating element for continuity. http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/7-3-850356-/GE-Dryer-won-t-stop-DWSR463EG7WW
This GE Website has descriptions and videos you can watch. Also shows the price of replacement parts and the skill level needed to preform repairs yourself.
Sep 12, 2014 | GE Dryers
My GE Profile Harmony dryer wont dry clothes
I finally had a GE authorized tech come to our house, because we've had the same problem on and off for about 2 yrs. Our's is 5 1/2 yrs old, and the problem was the blower motor, which is hard to get to, and the nut holding the fan in place is also put on going the "opposite" direction. (So lefty loosey, righty tighty doesn't work for this one) The Tech told me in all his years he has never replaced a heater in any of these, and it has 2. The usual problem is the blower motor has gone bad. It's working great now, and it was $470 to fix, but still cheaper than a new one....
May 14, 2010 | GE Profile Harmony DPGT750EC Electric...
Lightning strike power surge partially disabled dryer.(Whirlpool)
If it took a lightning strike something in the heating coil is shorting to ground tripping the breaker. DO NOT Keep trying it, you could cause more damage or even burn your house down.
Sep 29, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Harmony electric dryer model DPGT750EC1PL- very little heat - small rattle - takes hours to dry load of laundry... any ideas?
Check the following to address this issue.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Jun 06, 2009 | GE Profile Harmony DPGT750EC Electric...
GE Dryer doesn't give out heat.
OK, i would check the thermal fuse. is usually located on or around the blower housing. Check the vent duct if its not on the blower motor housing. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If the fuse is OK, there is only one more problem spot and that will be the timer itself. replace the timer/control if the fuse is OK.
Jun 01, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer not heating properly..taking longer to dry clothes
If there's heat inside the drum the heater coils should be ok, however your model has 2. With the door open and the machine running, look inside at the back of the drum and look for 2 glowing element coils. If one is not working you will not have enough heat.
Check the exhaust vent, make sure it's not kinked or squished behind the machine and that the outside vent is not clogged with lint. You should feel air blowing freely to the outside.
If there is no heat, first check for 240V at the outlet. If you have 240V, it could be the element, the hi-limit thermostat, the thermal cut-off, the timer, the motor or a wiring issue (loose or shorted).
Good luck!.
Mar 06, 2009 | GE Dryers
Dryer heats with smaller loads
1. unplug your machine and rach as far in the exhaust part of the dryer to see if there is an obstrucxtion
2.Take out the lint filter and make sure there are no gaping holes in the screen
3. Check the exhaust house leaving the machine or blockage, this hose should not run more than ten feet for optimal drying time.
4. its your heating element
Jan 19, 2009 | GE DBXR463EBWW Electric Dryer
GE JVM1870 Runs, but won't heat up
use a high voltage probe to check high voltage, if present replace the magnatron if no HV replace the high voltage board this is the board that has the heavy wires to the magnatron
Feb 06, 2008 | Microwave Ovens
GE DCSR483EA Electric Dryer Logo
169 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
vince
Marc Taylor
Are you a GE Dryer Expert? Answer questions, earn points and help others
