Question about Jenn-Air JGR8775QD Gas Kitchen Range
I have a jennair and the paint is peeling off the top haow can I remove it and let the stainles that is beneath show
  • 77 Answers
Sorry but thats not stainless just shinny metal for now.
Posted on Nov 17, 2009
Peeling paint on cinderblock walls in basement
Just a guess, but it is likely that moisture is causing the paint to peel. I suggest you remove as much peeling as you can with a wire brush and then use a waterproof sealant. I had very good luck with a product they sell to seal cement walls in basements with moisture problems.
Mar 09, 2015 | Cars & Trucks
What can i do to fix peeling paint on a wall?
scrape, sand, Prime with an acrylic primer ,skim texture and top coat
or call a professional
Jun 25, 2014 | Tools & Hardware - Others
Firebox disinigration
if the paint is peeling off heater is overheating check gas pressure if too low heater will soot up and overheat
Jul 09, 2012 | Teledyne Laars Pool & Spa
Inside of microwave top peeling and blistering
If it's paint peeling, then once that paint is gone, rust will set in, which can cause arcing and disintegration of the chassis, when ruins the oven.
This peeling is usually the result of excess moisture accumulating in the oven due to blocked air vents or poor fan circulation.
Once those two issues have been ruled out or dealt with, then always be sure to dry out or leave the microwave open after use.
The peeling paint will need to be removed, then the area should be sanded.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
We're
happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
Nov 28, 2011 | Morphy Richards AM925EF Microwave Oven
Top of range paint peeled. Buy new top
You will have more luck finding this top on ebay go to appliances and put in all info, untill you find one, i do this a lot when i cant even get parts, and i hav a shop, you will find one
Feb 17, 2010 | Kenmore Kitchen Ranges
Need to repaint bubbled and peeling paint on top of dryer
The choice is yours. Money often motivates these decisions. If the model number you have this listed under is correct, the top panel price is roughly $108 to $160 depending on the color you need. White or Bisquit is the cheapest, while Pewter is the most expensive. If you wish to replace it, appliancepartspros.com carries it for the cheapest price.
If you wish to paint it, remove the panel from the dryer first by locating and removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. This will allow you to work on it in a more convenient location and avoid any overspray from paint on your appliance. Make sure you clean the surface throughly to remove anything that may have caused the paint to bubble and peel in the first place (Ospho is commonly used to clean metal surfaces in preparation for painting - clean AFTER you sand). I would sand with a fine grit sand paper or emery cloth to ensure you don't leave any surface scratches. Prime the entire panel to provide a good surface for the new paint to adhere to. Once the primer is dry, apply a couple of good coats of appliance paint. If you have questions, please let me know. I hope this helps you.
Sep 06, 2009 | Whirlpool GEW9250 Electric Dryer
Paint inside lid peeling off when I cook
From Weber.com Don’t worry, it’s not paint. The inside surfaces of our grill lids are not painted, they are coated with baked-on porcelain enamel which cannot peel. What you are noticing is a deposit of grease and smoke that collects during normal use. During use, the grease and smoke vapors slowly oxidize into carbon and collect on the inside of your lid. This deposit will eventually peel, and looks very similar to paint. The peeling normally starts in the center of the lid and spreads outward. It may come off in sheets or flakes, and is shiny on one side and dull on the other. These carbon deposits are non-toxic. But you might want to regularly remove the build-up. Fortunately, the peeling is easy to remove. Simply brush off all loose particles with a brass brush before you start grilling. To prevent future build-up, after every grilling session, while the grill lid is warm—not hot—wipe it with paper towels or a mild soap-and-water solution.
Apr 25, 2009 | Weber Genesis Silver C Grill
Paint on top inside of lid is peeling off.
Remove the paint. The heat will dry the metal and grease from cooking will keep it from rusting, if it's iron. If it's aluminum it's not a problem.
Mar 14, 2009 | Weber Genesis Silver B Grill
Peeling paint
Here is a link to buy the paint.
If the microwave is not creating a spark inside when in use, It's OK to use.
Mar 09, 2008 | Rival MT660 Microwave Oven
Open Questions:
Jenn-Air JGR8775QD Gas Kitchen Range Logo
195 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
