No red in picture
I have a Phillips Tv, 55 inch projection hdtv, approximately 5 years old, but with only about 3 years of use on it. A few weeks ago the picture began to lose its red color intermittently, now the picture has no red at all, but it does continue to flash red lines here and there. Any ideas?
Thanks!
Holly
  • 281 Answers
It could be a dry solder joint on the base socket pcb. Try resoldering the base socket, and try for dry joints on the main board also. Check if the rgb voltages are steady on the crt driver transistor bases.
Posted on Jan 24, 2008
Red wavy red line on top of picture.faces distorted, but bottom part of picture ok
sounds like you have an output power supply going bad.
the tv is crt projection...which is to say due to its age and technology it will probably be cheaper to just get a new tv.
Sometimes these older style sets end up with compenent board solder breaks that can be spotted visually and fixed by a talented repairman.
My friend had this done to a similar 55 inch set he has about 3 years ago....he just won't give his up either!
good luck and be careful! There is lots of high voltage inside that tv!
Jan 15, 2010 | Akai PT5598HD 55" Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
http://www.tvrepairworld.com/
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Clearer HDTV picture?
quite possible that the coolant is getting contaminated as thats a normal occurance with phillips after a few years. If the color seems dim and not focusing properly its almost certain that the CRT coolant will need changing
Dec 28, 2008 | Philips 55PW9363 55" Rear Projection...
APPROXIMATELY 3" GRAY LINE ACROSS THE TOP OF MY TV
Do you happen to have a cable box? (reset cable box also by unpluging it). is that line also showing on dvd player on different input?
Jul 01, 2008 | Toshiba 50HM67 50" HDTV
Only red bulb working
Tried restoring to factory settings? Only blue was working for me and it helped *shruggs*. You can try... On the remote, press MENU then 1 2 3. Hit Enter. And it's restored to factory settings :]
Aug 24, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Problem w60 inch using hdtv cable box
i know this problem, happened to me with the comcast Motorola HD receiver box. The key is with the setting in the cable box. Switch on the TV. Set the channel to normal tuner channel 3 or HD input. Turn off the cable HD box. Press the Menu Button on the Cable box or the remote. You should see a Menu. Use the cursor keys to navigate The default setup is also one of the option, Right click on your cursor keys acts like the computer keyboard enter key and applies the change. The default setup is 16:9, the shacking would happen if you have set the picture type to "PAN SCAN". change it to either 16:9 or 4:3 Letter Box. The shacking should stop. Hope it helps.
May 15, 2007 | Philips 60PP9352 60" Rear Projection...
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
