Question about Music
Roland mc-303 Hey ! I plugged in my 303 to find this loud humming ! It works in conjuction with the volume control.I noticed that the wal wart receptacle is not the original one! could this be the problem? everything works on the machine, just want to get rid of that humming! Jimmy...
  • Music Master
  • 5,603 Answers
Yes, that is the likely problem.
The unit takes a 9 volt AC adapter with enough current.
Several sources are selling them on eBay. Search for mc-303 and some will come up.
Likely the adapter you have does not have enough current, hence the regulator within the mc-303 drops out of regulation paprt of the AC cycle.
Posted on Nov 18, 2009
Hi, Is it still possible to get hold of an On/Off switch for a Roland MC-303? Thanks
Contact Roland customer support at: www.rolanddga.com/support
Oct 22, 2017 | Roland Music
Sir i am from india i am purchasing roland bk5 since 1 year volume control of my keyboard does not work ...where should i buy that volume control plz help mee sir...
Might be best to contact the local service agent in India for Roland equipment.
Rivera Digitec (India) Pvt Ltd,
411 Nirman Kendra Mahalaxmi Flats Compound
(off Dr. Edwin Moses Road)
Mumbai 400011 Ph 022 24939051
If you do not have a user manual for this you can get it from
http://lib.roland.co.jp/support/en/manuals/res/62265052/BK-5_e4.pdf
Aug 06, 2014 | Roland Elektronische Musikinstrumente...
Hey I recently purchased a Roland TD-4 and i have no idea how to hook up an amplifier to it. My friend gave me a little amp, and i've tried many ports and cannot get it to play outloud. I'd like it...
First plug a set of headphones into the Left audio out and see if you get any sound from there... NOTE: it will only be in the left headset and this is normal. Turn up volume control... note the level will be low as this is a line output, not headset. This is a test to see if there is audio.
Sep 02, 2011 | Roland A: TD-4 Electronic Drum Set Pads,...
I have a Eupoport EPA 900 system. Recently I started getting a consistent, low pitch and fairly loud hum out of both speakers. The hum adjusts with the volume, and I have tested it with various working...
Is the hum there with NO input cables connected? If not, you have bad cabling. Make sure you use only XLR to XLR mic cables and not the junky ones with a 1/4 inch plug that are for Karaoke machines. These devices usually use switching power supplies and do not have the power supply originating hum of older equipment. If the volume control adjusts the hum, then the hum originates previous to the control which is either in the preamps or the external inputs.
Aug 25, 2011 | Behringer Europort EPA900 Ultra compact...
I have a very loud hiss/buzz sound coming from my Roland. It goes away if I lower the high volume knob. This just starred to happen recently. I tried changing connections from ch1-4 but no fix.
If this ties to a keyboard, make sure the keyboard and this are BOTH plugged into the same receptacle. You should send a higher level from the keyboard (turn volume up to around 70% or so) and use less volume at the input gain of this amp. Use more at master volume if the amp has one if needed. If the hiss is there with NO input cables plugged in and input gains at 50%, that is objectionable, the amp probably needs servicing. Unused channel gains should be clear down.
Apr 11, 2011 | Roland Elektronische Musikinstrumente...
I have a roland kc 150 65w amp that begins humming the moment i turn it on. its a normal low frequency hum. nothing is plugged into it, and when i ajust the volume knobs it does not effect the sound. How...
First thing is to determine if sound is from the speaker or possibly the cabinet. If from the cabinet it is likely the power transformer is vibrating the chassis. This sometimes can be cured by adjusting the mounting bolts.
If the sound is from the speaker, then an electronic "cure" is needed. Please note that a very quiet hum is normal but if you can hear it 5 foot away, that is un-normal.
The hum would probably be due to failing component in the power supply. Unles you are adept at electronic repair, best to take it in for servicing.
Feb 25, 2011 | Roland Kc-150 65-watt Keyboard Amplifier...
What should I do for connect the fc7 to Roland RD-700sx for controll the loudness? Thanks a lot Heinz
Yamaha pedals MAY not work on the Roland... However, read page 85 of your manual regarding the FC1 and FC2 jacks. plug the pedal into one of them and then assign/select that jack as controller #7 (CC7) which is the volume controller number used in MIDI.
Jan 23, 2011 | Yamaha FC7 Pedal EXpression
My roland kc-60 has a hum but i cant get any sound but that
Does the hum exist with no cable plugged in? If so, take in for service. If there is no hum with cable out, then try new cable and/or musical instrument be it guitar or keyboard as the problem is likely in those.
Nov 22, 2010 | Roland Kc60
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Music Logo
489 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
