Question about Panasonic Televison & Video
We have a red shadow on all images. Almost
We have a red shadow on all images. Almost watching TV in 3D without the 3D glasses. What is it ??
    President:
  • 788 Answers
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem. But if the set fixes itself you will need to have it repaired as soon as possible if you wait too long there are several components that will fail in due time. If you want to repair it yourself or know someone that can solder components on the circuit board, you will need to re-solder the convergence IC’s. All you will need is some solder wick, a good 45W soldering iron, Acid free solder and some solder wick (this is for the clean-up of solder joints and cleaning up solder bridges.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With any Projection Television that has a damaged or interment convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky
How do I tell if the IC’s are damaged?
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Posted on Dec 03, 2009
I turned My tv on and the top of the screen has red, green, and blue swirl lines, and the rest of it looks like watching a 3D movie without glasses, and the picture looks as if you took out the screen and...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows pictures or pictures look like 3D?Yes,than the tv convergence board it is dead.The tv convergence board must have it components parts replaced like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops will cost u like $300-$350 for parts and labors.
Aug 11, 2011 | RCA D52W19 52" Rear Projection Television
Hatachi 42inch hd projection whole left side has shadow effect blue and red 3d images without 3d glasses
Thats a convergence failure and will require installing a convergence repair kit. You can get convergence repair kits for Hitachi models at www.tvrepairworld.com they come with the ICs low ohm resistors and the CD with repair instructions.
Jun 17, 2011 | Hitachi Televison & Video
My Sharp 61 inch projection HD tv has a blue band of shadow that dips below the image. Looks like 3D without the glasses.
The tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B misalignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 20, 2010 | Sharp 61RWP4H 61" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
My Samsung rear projection 42" picture is blurred with a overspill of red shadows. its like watching 3D tv without glasses.
THE USUAL PROBLEM THAT YOUR SYPTOMS GIVE ARE ASSOCIATED WITH THE STK392- 090 INTEGRATED CIRCUITS 2 NEED REPLACING, UNLESS YOUR VERY TECHNICALLY MINDED ITS A JOB FOR A TECHNICIAN,COST IN THE UK ABOUT £150-00
Aug 01, 2008 | Televison & Video
Red and blue shadows on the pictures, as if watching a 3D movie without glasses.
Can you reply to this same post with your model number and I will try to assist you with your convergence problem.
Jul 09, 2008 | RCA Televison & Video
Samsung HCM553W 55 in. Rear Projection Television - image duplicated
Hello, I am a Samsung TV repair man. What happened was one of your bulbs in your tv has burnt out. you have to contact your samsung repair phone line. how old is that tv? do you have a warranty? if you do, it might be repairable for free. I hope this info is useful!
Apr 20, 2008 | Samsung HCM553W 55" Rear Projection...
Looks like 3d picture
Sounds like the convergence amplifier ICs . What kind of TV and what model number and I will be better equiped to help you.
Jan 13, 2008 | Mitsubishi WS-65413 65" Rear Projection...
My Hitachi 43UWX10B television
Needs Convergence IC
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
Dec 03, 2007 | Hitachi 43UWX10B 43" Rear Projection...
Red and Blue shadowing (Where are my 3d glasses)
There are two convergence IC's that are bad and need to be replaced, as this happens to almost every rear projectionj set ever made. They are stand up IC's , on a heatsink and they start with STK. They are soldered into place and this set has no user replaceable parts inside of it. If you have no solid state repair experience, you really should call out a trained tech to assist you in this repair. A TV set is no place to be diggin and experimenting inside of.
Sep 24, 2006 | JVC AV-48WP30 48" Rear Projection...
Televison & Video Logo
49 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
