Question about GE Nautilus 24" Built-in Dishwasher
Wheels keep falling off on lower rack, clips all
Roller wheels keep falling off on lower rack, clips all look good but are loose on the clip that snaps to rack, can i buy new clips or is there a fix for this problem
  • 441 Answers
The clips come with new wheels, they should cost about $4 for four, I would replace all wheels on the lower rack
Posted on Nov 17, 2009
Top tray wheels keep falling off
I feel for you! I have been tortured by the blasted wheels falling off every time I go to put something into the dishwasher, or want to empty it. To add to it all, this part is no longer available to replace, which I need to do as one of the clips finally snapped off. It is a highly frustrating design flaw in this machine.
Feb 25, 2014 | Baumatic 23 in. BDW5 Built-in Dishwasher
I have a GE profile dishwasher. The wheels on the lower rack have all come off and I can't seem to get it back on. On some, the piece that snaps to the rack is either broken or melted off somehow. Do I...
You just need the wheels. I have bought the upper rack wheels before, now I need the lowers. I have found a site selling them at 10.00 each. I am going to keep looking, I think I can do better, considering I need 4. I might just buy a new washer if I have to spend 40.00 plus shipping! I will post back if I find a better deal.
Jan 08, 2011 | GE Dishwasher Lower Rack Roller WD12X10262
We need new wheels for our lower basket
Hi, Welcome to "Fixya" ! You can find these lower rack support roller & clip assemblies at "repairclinic.com" for around $10ea. Their part number is 1156665. They are really easy to change as you may already know, they snap in place. Hope that is the answer you where looking for, let me know. Thanks for visiting "fixya" with your inquiry. Please take a second and rate my answer accordingly or if more assistance is needed post a reply. Good luck. Macmarkus :)
May 04, 2010 | Asko D1776 Built-in Dishwasher
Samsung ML2010 laser printer paper feed roller belt
I just fought this same battle and have emerged victorious! The roller cam that the black rubber belt fits around is kind of "C" shaped in cross-section. The roller has left and right hinge-pins on one end of the "C" and snaps on the other. Looking at either side of the casing that the roller mounts in, you will see the end of the hinge-pin and a typical sqeeze clip like those often found on bigger laser printer rollers. I'm sure this was designed so that you should be able to sqeeze the left and right clips simultaneously which should release the snap end of the "C" and allow it to hinge out away from the casing. Unfortunately, it appears that the designer's good intentions were never tested. If your roller is like mine, it does not freely release by just sqeezing the clips. It was a bit awkward but while squeezing one of the clips, I used the tip of a small screw driver to pry loose the snap on that side. The trick is to hold that snap out away from it's seated position while you perform the same procedure on the other side. With both sides pryed away from their seated position you should be able to hinge the roller with black rubber belt away from it's case and remove it. In lieu of buying a replacement belt I simply rotated the existing one to expose the unused part and snapped it back in place. Voila!
Jan 26, 2009 | Samsung ML 2010 Laser Printer
LG DIshwasher
hi Problems with the dish racks usually occur because the racks have been jammed back into the tub housing after they're fully loaded. Careless handling can exert enough force to crack or break the roller wheels or throw the racks off the tracks. The solution is easy: Stop jamming the racks.
The repair is easy, too. Remove the racks by pulling out the tiny metal pins that hold them in the tracks. Or simply lift up on the racks and pull them out of the tracks. Then reinstall the racks on the tracks so that they roll smoothly. If the rollers are cracked or broken, replace them with new ones of the same type. The rollers may be friction-fit to their hubs. Pull them off for replacement. Or, if they are held by tiny spring clips, pull the clips out with pliers, or pry them out with the tip of a screwdriver. If you can't pull the rollers off for replacement, remove and replace the entire rack.
Sep 12, 2008 | LG Dishwashers
The bottom rack of the dishwasher is always coming off the "track" or what passes for one. The wheels seem too small or the rack isn't wide enough Makes it very diificult to push in or pull out.
A noisy wash cycle or water that won't drain are problems that, for the most part, can be handled yourself. We'll discuss how you can pinpoint these water-related problems in the next section.
tha...........
GE dishwasher nautilus - bottom tray caster wheels come off daily.
I finally found a solution after 2 years! Appliancezone.com has wheels and studs to fix problem. WD12x10136 and wd12x10277. About $17.00 and rack is rolling perfectly. GE wanted 200 for an entire rack, no thank you!
Apr 06, 2008 | Danby DDW1805W Designer Series...
GE Nautilus 24" Built-in Dishwasher Logo
859 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
