Question about Hitachi P50H401 50 in. Plasma HDTV
I do not have the usual problems with this TV. About 90 percent of the time the tv has a hazey green tint. This is not a strip of green, this is the whole screen. Picture looks great when it does work right. I am told bu Sears that it could be a cable or the main board. Any ideas? Even when the TV is acting up you can still see the picture, it is just very ugly. I have tried every connector on the TV and they all act the same.
  • 441 Answers
Check your connection at the cable or sat box, most of the time its a bad cable, go to hdmi if the hook ups dont work
Posted on Nov 17, 2009
How do I repair a green tint on element tv model number PLX-4202B
Intermittent green tint is a source problem. Cable, satellite or HDMI cable.
Jan 02, 2015 | Televison & Video
Has green tint on screen
This is usually attributed to a loose wire if you are using the 5 component cables check both the TV and the Device it is connected to. If that doesn't work unplug both the TV and the devide it is connected to for at least 5 minutes. Does the trick 90% of the time
Dec 02, 2010 | Televison & Video
Have a green tint over 90% ot the center of the screen
I had the same problem with my 60V500A about a year ago. The screen got a red tint in the center and the image was fuzzy in that area. A new lamp didn't solve the problem. I did some checking and found out that the original light engine used in this model had a cooling issue that could cause the light engine to overheat and distort the LCD panels. My warranty had run out more than a year before this happened so I figured I was screwed since the light engine was so expensive. I decided to call Hitachi tech support and see if I could get a discount on the cost of a new light engine since the cooling problem was a known issue for this model TV. I calmly explained to them that I was aware of the cooling issue in the light engine and that I felt like a $4000 TV should last more than two or three years. Tech support gave me the phone number for my local authorized Hitachi service center and I gave them a call. Once the technician confirmed that it was the light engine that was the problem Hitachi sent him a replacement light engine at no cost to me. I was WAY past my warranty period so I still had to pay for the labor to replace the light engine. $300 for labor was a lot cheaper than buying a new light engine or tossing the TV and buying a new one. I have to say that Hitachi earned my respect for admitting there was a problem and doing what was needed to correct the problem more than a year after my warranty had expired.
Feb 20, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Picture tinted green
green tint & screen dark means that there is a problem in green video circuit. 1 check green video supply . 2 components in green video ckt. 3 adjustment in green video section. 4 check for signal to green video.
Sep 16, 2007 | Toshiba 36AF42 36" TV
Green tint on screen
Is it a green tint at some areas alone, oris the entire image having a green tint? If it is a color patch at the corner or other areas of the screen, in all likelihood it is a degaussing problem. Color patches happen when the TV is moved from one location to another, or if some magnetic source is placed close to a CTV. Did you put a radio or Tape recorder or Walkie talkie toy or any magnetic source near the TV? if yes, remove it. And the automatic Dregaussing circuits in the TV will resolve the problem in a couple of days. But if there is an overall Green tint on the picture, it signifies a problem in the Video output stages, and there is nothing you can do, but call the technician (unless you know solid state servicing?)
Aug 07, 2007 | GE 27GT619 27" TV
Occasional discoloring, tv randomly turns from green tint to no tint
Loose connections in CTR board ( picture tube), resolder it.
Aug 05, 2007 | Insignia NS- 27" TV27 TV
Hitachi P50H401 50 in. Plasma HDTV Logo
103 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
