Question about LG CE110 Cellular Phone
How do I put my LG CE110 in "pairing mode"? Do I just turn Bluetooth on?
How do i put my lg hbs-730 into pairing mode
It should automatically go into pairing mode if it does not detect the last device you paired it to when you turn it on. After startup it should say "ready to pair". Make sure all other bluetooth devices are turned off before turning on the HBS730
Feb 02, 2013 | LG HBS-700 Bluetooth Headset
How do you turn this device on and pair it with your phone?
to turn this device into pairing mode hold the power button down for 8 to 10 seconds,then a light should stay on.once you have put the bluetooth device into pairing mode you phone will find it and ask for a pin\pairing code.most bluetooth manufactures use a 4 digit pin\pairing code they are as follows ,0000,1234,9999,or 1111 and try them in that order one should work for you .Hope this helps
Mar 23, 2011 | LG HBM 730 Bluetooth Headset Wireless...
I paired my H710 with my lg Chocolate touch and the phone recognized it and it seemed to be connected. I haven't used it for a while and when I try to connect it says that communication failed. I have been...
To put your headset again in pairing mode, you must assure that your phone's bluetooth radio is turned off. Only then, open your headset's boom. After it is in pairing mode, turn your phone's bluetooth radio on, and make it search for new devices.
Hope it works for you.
Regards, Carlos
Jul 03, 2010 | Motorola Mobility H710 Bluetooth Headset
How to connect lg hbm-730 bluetooth to dv4 laptop
Be sure the the headset in in 'Pairing' mode.
When in pairing mode, the light should be flashing red and blue or have a steady blue.
The put most headsets in pairing mode, turn headset OFF, then hold the power button until it goes into pairing mode as discribed above.
Then you can discover it with your phone or PC. Pin (pass key) should be 0000 (4 Zeros) or try 1111, 1234, 9999
Feb 12, 2010 | LG HBM 730 Bluetooth Headset Wireless...
How can I get pictures off of my LG CE110 Phone, I have the cable.. but the Vista Platform says its missing a driver.. I can not find it anywhere.. help
The LG CE110 is a bluetooth device. You can buy a USB/Bluetooth device on ebay or online. Enable bluetooth on the CE110. Link the PC and the CE110 via bluetooth. Send pictures from the phone to the PC. 640X480 jpg files and 14 second mp3s can be uploaded from the PC to the phone via bluetooth for desktop and ring tones.
Oct 14, 2009 | LG CE110 Cellular Phone
Hoe do i put the lg hbm-760 in pairing mode????
Turn it on by holding the power button for four seconds, Then go to your phones bluetooth setup screen, search for new devices, and pair it. The blue led on the HBM-760 will turn solid blue during pairing. It is always discoverable. The default passkey is 0000. Hope this helps.
Jun 22, 2009 | LG Car Charger For HBM-710, HBM-760...
How do I put my used Plantronics Voyager 521 back in pairing mode My new LG CE110 can't find it
I have recently purchased a Blackberry World. I would like to connect my Plantronics with this Blackberry but, I have forgotten how to put it in pairing mode. Please assist me on how to do this.
Thank you
Apr 09, 2009 | Plantronics Hama Voyager 520 Bluetooth...
I can't sync my LG CE110 with my HS850 bluetooth
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Mar 11, 2009 | LG CE110 Cellular Phone
I cant pair motorola H350 to Voyager
Can you pair the voyager with anything?
Are you putting the bluetooth headset into pair mode correctly?
Feb 06, 2009 | LG VOYAGER VX10000 Cellular Phone
Pairing 730 and lg vx 860
To put the LG HBM-730 into pairing mode you must press the MFB for 5-10 seconds from power off. Pairing mode is denoted by the LED glowing solid red. LG has chosen to stick with the default pairing code of '0000'. Using Bluetooth specification 1.2, as is the custom, the HBM-730 supports both headset and handsfree profiles.
I found this on the internet and hope it works for you
Sep 05, 2008 | LG HBM 730 Bluetooth Headset Wireless...
LG CE110 Cellular Phone Logo
62 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
