Question about Ricoh Aficio 1515F Plain Paper Laser Fax
Error message -using handset (no handset on the machine. mfd - 1515
Hopefully, you're issue is long-ago resolved. If not, here is the quick simple answer. Even though you don't have a handset attached, you will get the message "handset in use" whenever the 1515 detects that the line is busy. So, if you have a phone line that is used for several faxes, or used for faxing and voice, if the fax attempts to dial out and detects that the line is in use it will display the message "handset in use" b/c there is no dial tone on the line.
Additionally, the line may not be in use anywhere else, but may just be 'down' so that no dial tone is present when the fax attempts to dial out.
This is a common issue in offices where the fax line is shared with a phone line or shared with a credit card machine (which dials out to get bank data) or just another fax machine on the same line.
Posted on Apr 19, 2010
  • 183 Answers
If this appear for the first time see the follow, if this started to appear after a time of usage you will need to call a Ricoh technician, sorry but i cannot gain some help in this type of problems.
see do you use a cord with two wires or four for Ricoh when using some telephone centrals like a Panasonic it's better to use a two wired cord for the line, if this still do not help, you will need to call the telephone central technician to set the line for the Ricoh fax.
Posted on Jan 26, 2010
My phillips laser mfd 6020 continually shows the message ""paper empty" although there is a stack of paper in the machine. What am I doing wrong?
The paper feed is detected with a INDETECT sensor/switch and if this is faulty the message will be shown. Also if there is a fault or error in the main board or processor this can be seen.
You can try and remove the panel and get access to the inner tracks to check the sensor , make sure that all connections are tight and there are no loose connections.
Mar 23, 2011 | Philips Office Equipment & Supplies
Ricoh 1515 is locked up with error message SC:820 code 612. How do I fix the problem
820 Self-diagnostic error: CPU
Symptom:
• An unexpected exception or
interruption occurs during the self-
diagnostic test.
• An error is detected in the MBU.
Possible Cause:
• Defective controller
• Defective firmware
• Loose MBU jumper
Code 820
MBU error (The jumper is loose.)
Set the jumper (on the MBU) correctly.
The following codes are displayed:
• SC: 820
• code: 612
• detail: 40000000
Feb 03, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
System error #1 Panasonic kxtg2770
1)On handset, press MENU, 0, 0, 1.
Handset display shows as follows.
*Skip this step when handset already shows as above.
2) On base unit, press LOCATOR for 3 sec until CHARGE LED flashes.
3) On handset, press OK button. Then wait until the handset display changes as follows.
If you receive an error message indicating the maximum number of handsets have been registered, you will need to deregister the handset from the base unit, then try to register again.
*If this does not work, your unit is defective. Please send your unit for service.
Panasonic Services Company Customer Servicenter
Suite B 4900 George McVay Drive
McAllen, TX 7850
McAllen, TX 7850
1) Press FUNCTION on handset. Then, using the Navigator key, press Down (V) 4 times, Right (>) 1 time, Down (V) 7 times, Right (>) 2 times.
2) On base unit, press MUTE. (MUTE LED flashes.)
Dec 04, 2010 | Panasonic KX-TG2770 Phone System w/...
Getting ERROR 5 message in my Cannon MP160 MFD
When your printer ink cartridge is ink run out or not support then rise this fault code.So you need a new cartridge.Insert new cartridge then solve this error.
Apr 11, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My fax wont work in my ricoh aficio 1515 mf??
Using the 1515 as a fax machine is a pretty simple procedure if everything works right. All you have to do is hook a working phone line up to the phone jack on the back of the copier (the one labeled LINE, not TEL).
Why won't the fax work? If it is giving you an error message, what is the message?
If you are not getting a dial tone when faxing, unplug the fax from the phone line and plug a working phone in, and see if the phone gets a dial tone. If it doesn't, there is a problem with your phone line.
You can also try plugging the fax machine into another phone line. If the fax works on that line, then there may be a problem with the first line.
Are you having problems sending faxes or receiving them, or both?
Jan 05, 2010 | Office Equipment & Supplies
Richo 1515 MF Error message: 12320 couldn't find the scanner.
This is a message on your PC...not the machine itself obviously? Was this scanner ever configured to work on your PC? If not, then follow this link to my comments to someone else about this machine:
http://www.fixya.com/support/t1718617-ricoh_1515mf_scanning
Feb 27, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
I can not use the scanner, Ricoh Aficio 1515. I alredy instal the twain driver ver.3 from the original cd, when I open the function palete, looks like its conected with the machine, but when I try to...
Visit the Ricoh download site and download the latest driver. This will ask you if you wish to overwrite, say yes. Hopefully this will replace the corrupt file.
Aug 01, 2008 | Ricoh Office Equipment & Supplies
Brother 1840 bleeps
Try to unplug the handset and try again.
Unplug the phone cords from any shared devices.
Do you have DSL or any other digital type phone line?
Make sure the phone cord is plugged into the LINE port of the fax machine.
Jul 21, 2008 | Brother IntelliFAX 1840C Plain Paper...
Mode incorrectly switching to Handset
Hi Sue, Can you tell me if there is anything else conencted to your fax line? Most Ricoh products will display handset if the dialtone is not detected. It could be that something is using the line or is causing it to short. Another thing to check if the machine is an older 1515- if this occurs after you receive a fax and you are behind a PBX, there was a batch of modems in the Ricoh machines that had a problem with not disconnecting the line, resulting in the handset being displayed. Could be any number of items, normally I would start the troubleshhoting with line issues and go from there.. Brad
Aug 17, 2007 | Ricoh Aficio 1515F Plain Paper Laser Fax
Ricoh Aficio 1515F Plain Paper Laser Fax Logo
506 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
