Question about Pioneer TS-W253C Car Subwoofer
Can it be used in a ported box??? If so, how many cubic feet and what are the port dimensions
  • 106 Answers
It dont matter, It will sound way better in a ported box.
Posted on Nov 17, 2009
What is the cubic feet needed to build box for audioban 12
You can use this speaker in either a ported or sealed box. A sealed box would be smaller, (sealed box volume: 0.5 to 1.25 cubic feet) the larger the box the more base you will get. With a sealed box your amp has to work double hard as it would in a ported box ( 1.3 to 3.2 cubic feet) You will get close to double the volume in a ported box. Tuning a ported box with the size and length of the port will determine the hertz the speaker will play at.
Sep 15, 2014 | AudioBahn AW1206T Car Subwoofer
Having two subwoofer 12w7 and running each of them with mtx1501d amp so i want know what size of box do i need for them and in which shape L box or sealed one.
id run a ported box they sound alot better and id go with a 3.5 -4 cubic foot box ported should slam loud i have one 12w7 and i flex my winshield in a ported box 2 cubic feet powerd by a jl 1000/1
Jul 28, 2010 | Jl Audio 12W7 Car Subwoofer
How many cubic feet does this sub take in a vented box
for a single one in a sealed box should be looking at 5 Cuft not prted, it varies on the shape of the box, wedge, rectangle, etc and if its ported, 5 cubic feet is generalised in a rectangle box thats sealed, heres a link, it is a little difficult but once you work it out you can calculate the correct cubic feet for any sub in any shpaed box, check it out.
http://www.the12volt.com/caraudio/boxcalcs.asp#ser
Jun 22, 2010 | MA Audio HK15X2 Car Subwoofer
2 15" and a 10" sub
10" subs need 1 cubic feet. 15" subs need 2.5 cubic feet. install them on its own volume of the box...
Jul 17, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Box recomendations
It depends on the size of the subs- 8z 10z 12z 15z? whether or not you port the box is up to you- a ported box is generally louder than a sealed box -as you are coupling and tuning the sound from the rear of the driver with the sound generated from the front of the sub- but the box is also generally larger as well.Then aside from your preference of ported/sealed you have to account for the recommendations of the manufacturer as to whether the sub/speakers are meant to be placed in a ported or sealed enclosure. Most 10 inch subs do well in a box that yields .75 cubic feet to1.0 cubic feet.most 12z do well in 1.0 cu feet to 1.5 subic feet and 15z do well in 1.5 to 2.5 cubic feet. I have a set of 15z that require 4.25 cubic feet per sub-so its important to look into the manufacturers recommendations. The easiest box to make would be a sealed enclosure-and the sound quality generally yields a tighter more accurate bass sound along with increased power handling capability- try going to rockford fosgate .com and look into the woofer box wizard its a program that calculates air space for whatever size box you have room for-hope that helps you-good luck
May 11, 2009 | Car Audio & Video
Box dimensions for 15 in cerwin vega
do you want the box ported or unported (holes or no holes) if you don't got a lot of room than you dont want a ported box. keep in mind the box has to have the correct amount of cubic air space or you could seize your sub... if you're building it make sure you use OSB board (oriented strand board) or MDF board(medium density fiber) your sub needs .7cubic feet of air space in an unported box
Feb 14, 2009 | Cerwin Vega IT-15.0 Car Subwoofer
Trying to find out wat the watts are on a jlw3 12 and a jlw0 12
The JL 12W0 needs 125 watts RMS. Sealed box it needs 1.5 cubic feet. Ported it needs 2.5 cubic feet.
The JL 12W3 needs 300 watts RMS. Sealed box it needs 1.25 cubic feet. Ported it needs 1.75 cubic feet. I wouldn't suggest running these subs together.
Jan 17, 2009 | Jl Audio 12W3 Car Subwoofer
What is the sealed and ported box volumes for the audiobahn dub 200 subs?
If you can access the inside of the sub box by removing the speaker, you may be able to measure the 3 dimension of each side of the enclosure.  1 cubic foot is 12x12x12 inches cubed.  That is 1728 cubic inches per cubic foot.  If you measure the inside dimensions of one of the enclosure sides as 10x14x8 inches, then that is 1120.  1120 divided by 1728 is 0.648 cubic feet.  Alternatively, you could estimate the volumes of each side of the box by measure the outside, figuring out where the box divider board is, subtracting the width of the boards used to make and then calculate.  Otherwise, I do not know the enclosure that that sub comes in.  Good luck.  Let us know how it goes.
Jan 02, 2009 | AudioBahn DUB200 Car Subwoofer
Dimension please for enclosure 12w3v2-d2
Typically you use one cubic foot per sub, so a 2 cubic foot box will work fine. To build a basic one, just a rectangular box, using 3/4" MDF (excellent material for a box), cut pieces this way:
2 - 25.5" x 13.5"
2 - 25.5" x 12"
2 - 12" x 12"
This will give you an interior volume of exactly 2 cubic feet. Cut your sub holes out of one of the 25.5" x 13.5" pieces.
Sep 24, 2008 | Jl Audio 12W3v2-D2 Car Subwoofer
Pioneer TS-W253C Car Subwoofer Logo
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
