Question about Bissell 3522 PowerForce Bagged Upright Vacuum
Brush heads won't spin - Bissell 3522 PowerForce Bagged Upright Vacuum
  • 701 Answers
Your belt is stretched, worn or broken and therefore not turning the brush. Here is a link for the replacement belts you need and the manual which has instructions:
Bissell PowerForce Replacement Belts
Posted on Nov 17, 2009
Why doesn't brush roller rotate?
The ends may be clogged with debris. You will have to remove the brush roller and remove one end cap to disassemble the roller for cleaning.
Jan 09, 2016 | Panasonic Mc-Ul594 Eco Max - Bagless...
Brush won`t spin on brand new vacuum
Hi! Many of our vacuums include a brushroll shut-off feature that needs to be activated in order for the brushes to spin. The brushroll shut-off pedal is usually located on the right side of the cleaner on the hood. Your instruction manual will show you exactly where your brushroll shut off pedal/button is located if your vacuum has this feature. Also, on many models the brushes will not spin when locked in the upright position. The handle must be reclined for the brushes to spin. Hope this helps!
Jun 13, 2014 | Hoover Vacuums
Brush no longer spins
Apply some Oil or crease in it to lubricate it! it will surely work
Mar 09, 2014 | Dyson DC39 Multi Floor Ball Canister...
Turbo head on DC39 animal will not spin. I have removed any hair etc caught around the brush but still no spinning..
I have the same problem with my DC39 Animal's brush bar. Im on my 3rd one in 9 months of ownership. The DC39 brush bar is driven pneumatically (there is no electric motor in the brush head) and switched on and off via a suction activated pneumatic ratchet within the brush head. The moving components are actuated by bellows. Ive found that the glue holding the bellows fails stopping the ratchet working intermittently at first and then completely as the bellows comes away completely. At first you can help the ratchet by tapping the brush head - the red ratchet ring can be seen to click round. This, in my opinion, is an inherent weakness of the DC39 design and cannot be easily repaired. The only solution is a new brush head. Luckily Ive got a 5 year warranty and at the current rate I will have got through about 20 brush heads !
Mar 31, 2013 | Dyson DC39 Animal Canister Vacuum
Dyson DC41 brush won't spin
You need to check the belt hooked to the side of the brush (sometimes hidden by plastic)
Jun 26, 2012 | Dyson Bagless Upright Vacuum DC41 Animal
Brushes don't spin
I'm sorry to hear you're having difficulty with the motorised brush head on your DC31 Animal. If the head won't seem to work correctly after you've checked for any obstructions, I'd encourage you to get in touch with us directly as we'd appreciate the opportunity to provide further assistance.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). Please have the machine to hand when you call, as one of our advisors may be able to resolve the issue with some troubleshooting over the phone.
We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
May 11, 2012 | Dyson DC31 Animal Bagless Handheld...
Brush inside main head doesn't spin, and stops spinning immediately after prompting it to spin. seems like the motor stop turning brush, however when i open main head and cover suction hole for a...
Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 13, 2011 | Dyson DC14 Animal Bagless Upright Cyclonic...
The brushes won't spin. I put new brushes on and it still doesn't spin.
Usually when the brushes won't turn it is due to a bad turbine. Insert a screwdriver into the square hole that the pin on the brush fits into, and see if it turns. If it is seized up, the turbine assembly will need to be replaced.
Jun 28, 2011 | Hoover SteamVac F5914-900 SpinScrub...
Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
Jul 05, 2010 | Dyson Ball DC24 Bagless Upright Vacuum
Bissell 3522 PowerForce Bagged Upright Vacuum Logo
212 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
