Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Bottom element stays on oven continues to heat. Temp guage preset stops at setting but element does not got off.
  • 1,543 Answers
You do not list a model number, but this condition is generally caused by welded contact points in the electronic control. (requires electronic control replacement)
Posted on Nov 17, 2009
Kems308sss05 starts heating to a preset temp, then stalls. Both broil/bake elements get hot, no spots or breaks. When I try to preheat again, the start temp is less than the # it stalled at.
Top 42 Complaints and Reviews about KitchenAid Wall Ovens
www.consumeraffairs.com > Homeowners > Ranges/Ovens/Stoves
Rating: 1.6 - ‎35 votes I missed 2-days of work, once for diagnosis and then another for them to ...KEMS308SSS05 - I purchased this product in Jan 2012. ... Ordered parts, two weeks later parts came and when the heating element was .... I used the self-cleaning unit in top and bottom and noticed in November the temperature took a long time to ...
Nov 08, 2015 | Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
Whirlpool accubake RBS275PDB6 will not heat up to preset temp
I am assuming the lower element is not working well. Go ahead and replace it. But first , go turn your breaker off to the oven and then back on. Often times it can be tripped but not showing due to the other poles not being tripped. The lower element is the cheaper one also.
Feb 24, 2013 | Ovens
Bake at low temp. Heating element vs control board
you need a meter that checks voltage (220) and continuity. turn off breaker remove screws that hold element in carefully pull it out just enuff to remove wires.remove wires check for continuity on element if there element is good. tape the leads to the wires turn on breaker, turn on oven if no 220 volts bad board or broken wire.
Feb 17, 2010 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven on RF263LXTT2 does not maintain a constant heat. Oven heats, but doesn't seem to continue heating at a constant heat during the baking process. Both coils heat up during the preheat. Seems like once...
The problem looks like a faulty electronic control. When you select baking, the broiling element should not come up.
Before replacing control assembly, test the temp probe located inside the cavity, check the wiring harness to temp probe and elements, and ensure that the fan is working if the oven is fan assisted.
Sep 18, 2009 | Whirlpool Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Nov 14, 2007 | GE JKP45 Electric Double Oven
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
148 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
