Question about American Standard Cadet 3 Right Height Elongated Toilet by - ADA Compliant
Water disappears to below the bowl inlet and stop.
After each flush the toilet bowl fills to 3 to 4 inches inside the bowl than water slowly disappears to below the water inlet inside the bowl and stops. Than I hear a small hissing sound. This is a new toilet.
  • 317 Answers
Adjust the float up to make water deeper....make sure no obstructions around the flapper....flapper needs to rest tight to bottom of inside the tank..flapper is the rubber peice that lifts when you push handle
Posted on Nov 17, 2009
Testimonial: "Thanks. Rubber on the flapper was torn. Hareware replaced the flapper. It work well now. Ciao"
Our WaterRidge toilet tank will not fill with water
This sounds like the float is getting stuck , while the toilet is trying to fill if you see the float ball that is attached to a arm that pivots , if you lift the float up it should turn the water flow off from trying to fill the tank , some problems that can stop this are the rubber seal that lifts up when you press the flush button to allow water to flush the bowl does not seal back in a position so that the tank can never fill , sometimes the float ball can get stuck which stops it from rising up with the water level and shutting off the water , but my best guess is that the rubber seal has started to perish or distort and needs to be replaced you can find this right at the bottom of the tank and it is directly connected to the flush button ,so if you inspect inside the water tank and press the flush button you will see that it opens up and lets water pour into the toilet bowl but if a tight seal can not be made water will never fill the tank
Sep 26, 2017 | Washing Machines
Why doesnt town water cut off and just keep filling the tanks till they overflow we have tryed everything
Troubleshoot Your Toilet Without a Plumber
www.popularmechanics.com/home/how-to/a4117/4303948/
Overflowing, constantly running and sweating toilets can test a home owner's sanity. ... take for granted--until we can't take a shower or make the toilet flush properly. ... If none of the above does the trick, you may have a misadjusted or faulty fill ... the waterlevel a half inch below the top of the overflow tube inside the tank." ...
Emergencies - Overflowing toilets - Toiletology 101
www.toiletology.com/emergenc.shtml
You can't just lower the water level in the tank; you need to displace some of ... and the ballcock and flapper are working properly and shut off when the tank is full. ... The bowl is filled with the water that goes into the overflow pipe. ... Unfortunately, when a toilet bowl is clogged and the water level rises and doesn't flush the ...
Nov 19, 2015 | Town Home
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
Toilet fills with water then slowly goes down
you have a blockage maybe outside in your shores
Oct 16, 2012 | Home
I have a new American Standard Cadet 3 that was just installed. After flushing, the water fills into the bowl. However, after several minutes, the water in the bowl slowly drains away and is nearly gone....
Sorry for problem with new toilet.
You say water is leaking out of the bowl?
Toilets have 2 parts:
1) Tank: where water is stored for the flush and is sealed with a flapper.
2) Bowl: where water flushes down.
a) If tank is leaking water, then flapper is suspect. Replace flapper and see if that works.
Lift up flapper and run finger around rim to see if there is a rough spot that would indicate flush valve is defective, and needs replacement.
See typical flush valve
b) If bowl is leaking, that is very unusual and would indicate a crack in the porcelain.
If installer sold you the toilet, it is his responsibility to make good on product.
All products are guarantee against workmanship flaws.
Feb 26, 2011 | American Standard Cadet 3 Right Height...
After flushing, water level in bowl fills and then slowly drops.
Check to be sure small tube is flowing inside the ovefow tube. This is the water that flushes the rim holes, and refills the bowl. If you don't have flow clean or replace the float valve.
Jul 19, 2010 | American Standard Cadet 3 FloWise...
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
Jun 22, 2010 | Pegasus Technologies Two-Piece Round...
Basement toilet drains slow sometimes ,other times doesnt want to go down all the way. seems as if there is no pressure to remove waste
if the toilet is old or not cleaned proper, the water jets that shoot the water into the bowl might be clogged. If the jets are clogged with moldor hard water build up the toilet will not flush proper. If you can take a 3 gallon bucket of water and pour straight into the bowl and it flushes fine you have a water pressure problem as described above. the problem also might be that your water inlet system is not letting in enough water to fill the tank. If this is the problem you need to replace the water inlet mechanisim, such as a fluid master. If you use a blue water device that hangs on the side of the tank in the back of the toilet you might have a peice of it under the flapper that takes the water to the bowl when being flushed. Check under the flapper if you put cleaners in the tank.
Mar 23, 2010 | Crane Plumbing Toilet To Go Tall...
This was just installed. When it is flushed the
If there is a air emiten valve on vent ? Remove it than try to see if it works properly. If this works you will need pipe vent outside
Dec 21, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Water level drops in bowl after it fills
If very little water is used on initial flush, The bowl is functioning as a tank for second thorough flush. The high water level cannot stay high in the bowl while in motion or you would have a mess ion start and stops.
May 28, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
American Standard Cadet 3 Right Height Elongated Toilet by  - ADA Compliant Logo
686 people viewed this question
Top American Standard Home Experts
Mike
john h
allphase tech
Level 1 Expert
Are you an American Standard Home Expert? Answer questions, earn points and help others
